TriTom
What small parts would I need for sunroof seal replacement?
Hi all- I am having a time trying to determine what small parts (in addition to the velour-like seal for the rear) I would need? I want to replace everything that I can - 14 yr old car....the front seal is fine, and appears new. The rear is trashed...
Any help would be greatly appreciated!
Cheers, TriTom |
You don't need anything but the front and rear velour-like seals and the rear rubber seal if you choose to replace that as well. No little parts are needed.
'73 914 2.0, '74 911 Coupe, '74 911 Targa '78 924, '84 944, '86 944 Turbo, '84 911 Coupe '84 944 (current), '96 993 Coupe (current) '73 911T Coupe (current) '88 930S M505 (current) |
TriTom
Many Thanks......should not be "too hard" to follow the directions on this repair.....
Thanks again, TriTom
Cheers, TriTom |
TriTom
I am 1/2 way thru this job. Suffice it to say the Porsche factory manual provides an incomplete description of how to do this job. My neighbor and I puzzled thru it and finally got it out. Now let's see how easy it all is to put back in!
Anyone else had to do this job?
Cheers, TriTom |
