96 993 tip to 6spd conversion (possible?)
Hi,
I have a 96 993 that unfortunately is a tip and would like to look into converting it to a 6 speed.
Anyone have any insight into what is involved in this swap?
Computer? etc?
Thanks,
pj_alexandre@yahoo.com
Old 01-07-2003, 07:34 PM
Trent P.'s Avatar
Just curious what your reason is for doing this...not judging, just curious!
'91 C2 Guards Red Cabriolet (for sale)
Old 01-09-2003, 05:11 AM
None other than I want a six speed for the driving experience and enhanced performance.
Old 01-11-2003, 07:28 PM
I know 964's can be converted from Tip to stick. The good thing is you end up with a on board computer AND a 6 speed....
Chris
Old 01-24-2003, 07:42 AM
Sell then Buy a manual...
Keith
Drive Hard and Fast
1991 Carrera 2 Targa
1972 911T Coupe
1971 914
Old 01-24-2003, 01:17 PM
Thanks for all of your information posts on this matter. :|
Old 01-31-2003, 09:13 AM
jph83's Avatar
I was under the impression that the mounting between box and engine was slightly different on the manual compared to the tip so some modification may be necessary. I've seen a 964 thats had this conversion though, (to 6 speed 993 box from tip) so it must be possible.
If you can find a donor car with all the right parts it's probably worth doing but if you've just got the tranny you could spend a lot of time and $ finding all the other bits you will need.
Hope this helps, Jon.
Just because YOU think it's a stupid idea, won't stop me from trying it!
'83 Porsche 911SC -project moneypit
'89 BMW 325i touring - 300hp tow car
Old 02-01-2003, 10:33 AM
Senior Member
Hello
The bodys and axles are similar and therfore it is just a bolt up, but you need all the parts including some little things most people will leave in the junked cars and then you will have to buy them new or organize them expensive. If you are doing that in a shop the costs will run out from any relation except those guys have the car direct beside for a bolt over.
Grüsse
Old 02-02-2003, 03:38 PM
