993 twin turbo spark plug change frequency
How often should I change the spark plugs in my 1996 993 twin turbo motor? I do not track the car, but do drive it hard occasionally. What plugs should I use? It is a single plug motor with a DTA Fast engine management system.
Honestly,
These cars are pretty hard on spark plugs. I believe mine are changed every time the motor comes out or they even get near them for maintenance. Just going to get plugs done is like 6 hours labor or something insane. So any chance you get near them... Replace them.
the OEM plugs are great for these cars in a single plug. But check out a DENSO replacement. Iridium.
Every 20 to 30k should be fine for your use.
993tt & 997tt |
Thanks for the responses. The plugs are actually relatively easy to change since the engine is in my 1989 930.
