964 power window problem
My power window switches on both doors just stopped raising the passenger side window. it goes down but not up Whats the problem?
Old 05-11-2012, 06:51 PM
bleachii's Avatar
We recently had this issue with 1 window and it was the actual switch. Believe they are relatively inexpensive and simply pull straight off with help from small screw driver or putty knife to get some leverage. New one snaps on.
He did mention that you want the better (read more expensive) switch available as they tend to last longer. He said the cheaper version is wasn't worth the few dollars savings.
Your issue is slightly different in that ours wouldn't go up or down but maybe worth a shot at replacing one to see if that is the issue. My only reservation would be that they both do the same thing and you are saying it happened at the same time. You wouldn't think both switches would fail simultaneously.
'79 930 Minerva Blue/Cork
'98 993 Cabriolet Glacier White/Midnight Blue
Fire - '91 C2 Targa Black/Tan
Old 05-12-2012, 06:19 AM
Replace the switch with the OEM version from Pelican. I keep a spare in the glove box and find I'm replacing one about every 3 years. They pop out and push in.
Old 05-13-2012, 08:52 AM
WillemB's Avatar
I had the same problem, after a long long search it was a simple crack in a wire.
1991 964 C2
Old 05-14-2012, 08:29 AM
