-   Porsche 964 & 993 Technical Forum (http://forums.pelicanparts.com/porsche-964-993-technical-forum/)
-   -   Grinding Noise in C4 Help ????? (http://forums.pelicanparts.com/porsche-964-993-technical-forum/677537-grinding-noise-c4-help.html)
imladris 05-13-2012 07:27 AM
1990 C4 with 54 K on the clock. A week ago a grinding noise started when backing up and turning the wheel to the left. Does not appear when backing straight or underway at road speed.
Had it in to a local indy and they didn't see anything remarkable. Suggestions, comments please before I hand the C4 over and the wrenches start turning along with my wallet. Had this car since 06 and nary a problem.
Lastly, any suggestions for a top quality service shop in Tampa area. European******** ???? Autobahn, Tampa???? I'm familiar with Vortex. Thanks
jhg41977 05-14-2012 06:40 AM
Can you tell where the noise is coming from? Can you get the same noise going forward with the steering wheel in the same or reverse position?
herman maire 05-14-2012 08:45 AM
does it do it if you lightly apply the brakes ? How about if you lightly pull up on the E-brake? sometimes things get loose in there .
iamtheari 05-14-2012 11:12 AM
What about backing with wheel turned to the right or low-speed forward movement while turning? I would check the power steering fluid and consider a front differential flush and fill.
CaptainCalf 05-17-2012 09:57 AM
I haven't used them yet, but have a buddy who has a 930 who recommends them:
Vortex Motorsport - Porsche Audi BMW Mercedes Auto Repair Tampa
Newsboy 05-22-2012 03:25 AM
What did the Indy say about the noise? Where is the grinding noise coming from?
993PorschePower 05-25-2012 01:54 AM
Sounds like the same problem I had. Then it was the steering rack. Check for leaks. Also check ball joints and tie rod ends.
Ken
GeorgeK 05-25-2012 03:34 AM
Check the power steering fluid level. likely low.
Brandon-FL 06-06-2012 04:59 PM
Have to agree with the others, check steering rack for leaks and power steering fluid level. My C4 developed a groan/grind and only noticed at low speed turning (like in and out of the garage). Steering rack was fine, but found a leak on one of the hoses connecting to the steering fluid reservoir.
FYI, I have a 1990 C4 and highly recommend Leo Leal at German Specialties in Oldsmar 813-818-0993.
