retired
Pulse Sender/Crank Sensor workshop manual/bulletin?
I wonder if anyone has any info about the replacement Pulse Sender/Crank Sensor and in particular to the plug socket, connector and the gasket?
There is a workshop manual "993 KD-NR. 97 50 41" for the install probably related to the modification to the plug. Does anyone have this workshop info handy or shed some light on what is required before I get in there? Here a picture of the parts:
hans '98 993 C2S '97 993 C2 † |
Alps Adventurer
What exactly do you want to do with what you have pictured? |
retired
I think the original plug can break down from age and there is this optimized plug connector that replaces it. When ordering the Pulse Sender it also specifies to order the plug parts as pictured.
This morning I got a copy of the workshop manual explaining the procedure. I realize now I needed 3 of the connectors and 3 of the little gaskets. That makes sense as it suggests to cut all three wires next to the old connector housing. I only ordered one of each. Duh!
