group911@aol.co's Avatar
Originally Posted by group911@aol.co View Post
Bill
I might be wrong but I think the torque tubes are different 993 to 964. The 993 shaft is about half the diameter of the 964.
Bill
Finally got some time to compare. Ill do a separate post showing the differences but they are not interchangeable. 964 vs 993 Torque tube differences
Thanks,
Bob
group911@aol.com
Old 08-08-2012, 06:49 PM
Geary's Avatar
Yes, I'll be watching this thread closely, too. A VERY worthy project, Duke.
Old 08-09-2012, 05:42 AM
duke of boots's Avatar
Flywheel/Clutch combo
Does anyone out there know if the 964 flywheel will fit a stock 911 2.0L motor? Will make this project so much easier if it does.
Old 08-12-2012, 07:19 AM
syncroid's Avatar
It won't fit. A 964 flywheel is a 9 bolt pattern and the 2.0 motor is a 6 bolt pattern.
Dan
2002 996 C4 Cab w/ Jake Raby 4.0
2024 Tacoma TRD Offroad 4x4
2003 Range Rover HSE
Old 08-12-2012, 07:27 AM
DW SD's Avatar
I wonder if you can use a 964 clutch disc in between a 2.0 flywheel and pressure plate?
the 964 clutch disc is 240mm, I think.
Doug
1971 RSR - interpretation
Old 08-12-2012, 08:15 AM
Nuts
Ah nuts, well bolts actually and 3 too many. May have to be a bespoke flywheel. Thanks for the swift replies.
Old 08-12-2012, 08:44 AM
Flywheel builder
Can anyone in the UK recommend a flywheel builder?
Old 09-02-2012, 12:08 AM
Breckskier's Avatar
How did this go? Just curious.. I've got a 13w deluxe at the body shop & about to turn a 912 to 911. Never considered a C4 Splitscreen....
Would love to see more of how the project went.
Old 09-02-2014, 06:10 PM
Hi All. If anyone is interested this is how the build is going
https://www.ssvc.org.uk/phpbb/viewtopic.php?f=8&t=86279&sid=14f7cf273de49f2d546f464567ac2cac
So far it has 964 front suspension, 996 rear sub frame, 993 engine, 981 gear shift - fun fun fun
Old 03-07-2021, 11:47 AM
How all Split Screens should be pushed down the road -
https://www.flickr.com/gp/78596025@N06/GNa6iqg6SX
Old 10-02-2022, 09:37 AM
Bottom end in by Duke of Boots1966, on Flickr
Old 10-02-2022, 09:38 AM
Old 10-02-2022, 09:40 AM
996 rear suspension
Rear Sub Frame by Duke of Boots1966, on Flickr
Old 10-02-2022, 09:42 AM
964 transmission in chassis
Chassis and Suspension by Duke of Boots1966, on Flickr
Old 10-02-2022, 09:43 AM
964 front trans and hubs with 964 steering rack mounted upside down
https://www.flickr.com/photos/78596025@N06/shares/G226h6WF8d
Old 10-02-2022, 09:48 AM
