-   Porsche 964 & 993 Technical Forum (http://forums.pelicanparts.com/porsche-964-993-technical-forum/)
-   -   Just when you think you have everything under control..... (http://forums.pelicanparts.com/porsche-964-993-technical-forum/698567-just-when-you-think-you-have-everything-under-control.html)
Bill Verburg 08-25-2012 06:24 AM
liquefied CV joint grease pouring from the axle weep hole
http://forums.pelicanparts.com/uploa...1345900928.jpg
patfat 08-25-2012 10:22 AM
Been there buddy :(
Flieger 08-25-2012 12:13 PM
I hope that did not get on the tread. That would certainly make for some interesting handling. :eek:
Vandit 08-25-2012 01:45 PM
What's the solution here? Repack w/ higher performance grease?
Bill Verburg 08-26-2012 03:51 AM
turbo axles packed w/ Krytox, unless I here a better suggestion.
The RSR took cooling air thru the 1/4 windows and ducted to the half shift joints
Jim Richards 08-28-2012 02:52 AM
Bill, you really are driving the wheels off of your car. :)
Bill Verburg 08-29-2012 02:13 PM
Hopefully repaired
Genuine RS axle nuts added to boot
http://forums.pelicanparts.com/uploa...1346274711.jpg
TRE Cup 08-30-2012 10:30 PM
here is a mod some of the cup car guys do to keep the grease off the rims and tires: They plug the vent hole.... and install a similar diameter stainless tube between the boot and the half shaft. Its held in place by the metal "tie wrap" on the end of the accordion . That way the gases that build up spurt out towards the center of the car rather than to the outside
