What a mess!!!!!!!!!!!
Doesn't every body have a engine that looks like this???? I am taking any suggestions on how to get this thing clean for disassembly. Thanks for any suggestions.
Old 09-04-2012, 08:31 PM
Bandwidth AbUser
Jim Richards's Avatar
Like what?
Jim R.
Old 09-05-2012, 02:21 AM
redturbo911's Avatar
NO pictures are showing.
Tony
91 964 c2 black/ Work in progress/Finally back on the road
85 EURO 930 Black slightly moded slowly reviving her
77 911tt EFI wide body red/ Slightly modified SOLD
Old 09-05-2012, 07:18 AM
that is funny!!!! I forgot to post pics. LMAO!!!!!
Old 09-05-2012, 01:02 PM
Oleg Perelet
this?
Old 09-05-2012, 01:18 PM
Originally Posted by perelet View Post
this?
I was hoping you would not say that.
Old 09-05-2012, 02:08 PM
Alps Adventurer
Traveller's Avatar
Here are a few...kerosene, Dunk for starters. Then a water based degreaser like Swish Facto AT30.
I'd seal off the engine better than that.
All the best,
Alex
1995 Carrera 2 - Speed Yellow - Alps Touring
Old 09-05-2012, 06:45 PM
Thanks for the suggestions Alex. What is Dunk for starters? How should I better seal the engine? Would you suggest a pressure wash at some point?
Old 09-05-2012, 07:56 PM
Alps Adventurer
Traveller's Avatar
Its a oil based degreaser which is used to get the majority of crud off engines, transmissions or engine bays. These kind of products come in a spray or container. I prefer the latter. Use a 1" pure bristle paint brush.
Make sure nothing can get by your rags. I don't let them stick out either...they can be dislodged too easily. I prefer paper towels and I replace them often as they get dirty.
I certainly wouldn't, although I am sure some might. Looking at that engine, I'd probably be a day on it.
All the best,
Alex
Old 09-05-2012, 08:14 PM
I do plan to pull the heads after the cleaning.
I will look for the products. I have already spent a bit of time on it already. After this it is on to the 930 gear box.
Thanks again for your time and information.
Old 09-05-2012, 10:41 PM
Now in 993 land ...
aigel's Avatar
Not sure why you'd clean it before disassembling? If the heads go out for rebuild, the machine shop will clean them. Same for case and cylinders. I'd get the big chunks off with a wooden spatula and forget about it. Wear nitrile gloves.
If not all goes out to a machine shop, I'd get busy with some "gunk" engine degreaser and brushes. I'd use a large plastic bin underneath (I like the concrete mix bins) to catch the mess and also to be able to re-use the engine degreaser a couple times. Make sure to work in a well ventilated area and / or to wear a respirator.
G
81 SC (sold)
Old 09-05-2012, 10:58 PM
G
JUst the heads will be going out and I would at least like to get the majority of the mess off first. I will be media blasting them for my machinist. The block/barrels I am afraid are all brushes and rags. Good idea about the concrete mixing tub. Wish I had a dry-ice blaster.
Old 09-05-2012, 11:57 PM
Bandwidth AbUser
this?
I prefer the ergonomics of the toothbrush holder on the left.
I used aigel's method to clean a flat-6 a number of years ago.
Jim R.
Old 09-06-2012, 05:16 AM
"To be fair..."
Resident Sicko's Avatar
I prefer the one on the left as well. Do you have her contact number so I can put her to work?
1998 993 C2S
2014 Ford Focus ST
Old 09-06-2012, 08:02 AM
get in there and do it!!!
well now I have done it!!!! ( with the help of my forced labor) I made a clean spot. Now I have to do the rest.
Actually she is the boss.
who would have thought a 4 year old could know so much about cleaning a engine.
Old 09-06-2012, 02:06 PM
Old 09-06-2012, 02:07 PM
Starting young I see. LOL. Reminds me of when my 4 year old stuck her hands in the oil bucket after an oil change and thought it was funny......... Her mom however did not find it funny.
Tony
Old 09-06-2012, 06:34 PM
Alps Adventurer
Traveller's Avatar
Unfortunately, Facto AT30 water-based degreaser isn't available at the local Pep Boys or Advance Auto Parts. Swish has outlets in NY and VT. One P-car owner in Chicago had to order a pail.
These are the before and after results.
All the best,
Alex
Old 09-06-2012, 06:55 PM
This one actually sat in a fresh bucket of changed oil after a oil change on my 911. What a night that was. My wife laughed her head off until it was bath time.
Old 09-06-2012, 07:49 PM
Thanks Alex
I (we) are fighting through it with tooth brushes, bristle brushes and lots of paper towels. it is not coming out too bad so far. Just takes time.
Old 09-06-2012, 07:50 PM
