GBX GBX is offline
GBX's Avatar
Von vs KW vs Bilsteins
What's the best coilover suspension for a 964 that will be used as a weekend "canyon carver". It will see very little, if any, track time. Really looking for a comforable but sporty coilover system.
Or am i better off with just some shocks and springs (non-adjustable)??
Old 03-13-2013, 08:20 AM
cgfen's Avatar
look into the KW V3 line.
they are double adjustable and may be set a tad bit "softer" than the P10s when you want comfort.
2012 Cayman R Chartreuse / 3 pedals
2009 2S Nordic Gold over Cocoa, my sweeties car (Chairman Meow)
2024 Audi A4 Allroad Navarra Blue over Grey
2010 Audi A6 Avant Grey over Grey - Supercharged!
Lottsa "steel is real" bicycles
Old 03-13-2013, 08:32 AM
Bill Verburg's Avatar
revalved Bilstein or H&R hd shocks or Bilstein Pss10
Bill Verburg
Old 03-13-2013, 08:36 AM
GBX GBX is offline
GBX's Avatar
Can't find much on Von Coils but my builder is recommending them. Any opinions on those?
Also, with revalved bilstein shocks, what springs do i use?
Old 03-13-2013, 12:23 PM
there are different ways to go, you can use stock, or any of several other stiffer setups, some require new perches and mounts so research fully.
use digressive valves matched to the springs and car weight
PSS10 come w/ digressive's springs and any other hardware needed
Bill Verburg
Old 03-13-2013, 12:44 PM
Shamus911's Avatar
Another nod for the KW V3 - just an excellent bit of kit and their customer support in the US is excellent.
KW V3, B&B exhaust, SW chip, RS clutch/flywheel, Walrod & Powerflex bushes, Rennline camber plates, RS heat bypass, RS fog ducts, RS engine mounts
Old 03-13-2013, 02:02 PM
