Today I purchased Fister stage III for my 993
So today I purchased the Fister Stage III mufflers from FD motorsports. I them with the ceramic coating in black with the fister exhaust tips, also in ceramic coated in black.
Video provided below with sound. i will be posting pictures when i receive my package and during the install, with a sound clip after the install. FD Motorsports » Fister Exhaust – 993 Stage III FD Motorsports » 993 Exhaust Tips – “Wide Ovals”
1966 912 with 2.2 911 motor 1986 wide body 911 1995 993 Polar Silver |
I have the same setup and you might LOVE IT!!!!!!!
Do you have the short shift kit + golden rod from FD?? that is a must as well (and the list goes on from there :P) ![]() phil. |
golden rod? the po had a short shift installed before i bought the car?
i found the golden rod. hmmmmm i have to sell some left over parts from my 86 911 first. i just bought this car two weeks ago. thought i was stopping at the exhaust.
Did you happen to pony up for the ceramic coating? As hot as things get under the 993's, its a good idea to lose the cover under the motor, and I thought an extra step might be to pony up for the ceramic coating to contain the heat withing the exhaust system as opposed to letting it radiate under the motor.
Just curious, as I see FD offers the ceramic coating to the Fister kits...
If it flows, it goes. If its smooth, it moves. Any questions? 96 993 C2 (Current) 87 911 Factory Turbo-Look Cab (Sold) 85 911 Factory Turbo-Look Targa (Gone) |
I got the ceramic coating... so all the heat shields and mounts are off the cans.. lighter and cooler.. ROARS! also got velvet black wide oval tips
![]() (I know, I need to post pics!) phil. |
![]() Here is my fister stage 3 exhaust installed with the ceramic coated wide ovals. I will be selling the the oval tips I had on there before.
1966 912 with 2.2 911 motor 1986 wide body 911 1995 993 Polar Silver Last edited by kinein; 04-07-2013 at 05:40 PM.. Reason: correction |
I would like to find a.sport cat 200 or 300. To add with.the fister cans I installed
I've had the Fister Stage 2's for a little over a year now, very happy with the sound vs. stock. It's just enough.
Thinking about doing the goldenrod and possibly the SSK, I've read where the SSK puts the shift lever knob about an inch higher, not sure I'd like that though. |
yes i saw the golden rod and ssk at the festival of speed. it seems like it would be taller. which i wont like either. but the golden rod is something i am leaning towards.
I'm have been running Stage II's for ~ 2 years and love the tone ... just right for my neighborhood :-). I went with the SSK and Golden Rod this last fall.
I don't even notice the extra height anymore. I have seen an installation where the shifter was cut down ~ 1 inch and modified to accept different style knobs ... nice, but I am happy with mine.
Kiwi01 85 911 Coupe ... Iris Blue metallic (sold) 95 911 Coupe ... Aventurine Green metallic |
any pictures of your ssk setup?
I'll try to get a picture tonight ... I think the thread with the modified SSK shifter was on Rennlist, if that helps ... I dont remember the thread title try searching on ... either SSK, GoldenRod or Shift Knob.
RE: SSK + Golden Rod
The SSK is the RS Lever which does raise it, but also adjusts the length of the ball at the base of the shifter.. which turns into shorter throws. You could cut some of the top off to lower the shifter. End result is shorter throws (good thing, just keep it slow until the transmission warms up).. a little taller, but I don't think its bad at all (maybe an inch?) start with that and then cut it down if you really want. Golden rod - this replaces the rubber between the shift assembly and transmission with a universal joint.. it will get rid of the sloppy feeling. SSK+GR= tight and fast shifting! IF you are running on stock you should do\try this combo. I recommend the combo on every 993 to modernize the shifting. ![]() phil. (SSK+GR+Fister Stage 3s+Wide Ovals!!!!! FD Rocks!) |
Here is a rough picture of the shifter and interior GR + SSK ... +1 to Philbur's explanation. In my case I was going to have to do something to fix the forward rod cups ... installing this combo is a very nice improvement.
Like I said before you get used to the height ...
Wide body, molester.
I thought I would hate it but its easy to get use to and a small prices to pay for a great shifter.
91- 964T, It's upkeep treats me like a skinny white kid in prison, but it does give me a reach around every now and then by letting me drive it. That's not so bad. |
Not Bad
I'm guessing you could cut the 1" off simply with a grinder / cut-off wheel. Would that affect the ability to reuse the stock knob?
