LinkBack Thread Tools Rating: Thread Rating: 1 votes, 4.00 average.
Belt sender/sensor
Hi - I'm new to the forum and a new, proud owner of a 993 C4. I noticed the fan belt sender/sensor wheel has been zip tied away from the belt. I read on this and other forums that they sometimes start squeaking badly. I'll guess that's why the previous owner tied it up. Regardless, there are no lights on the dash. The connector seems to be properly connected. My question is, why arent there any lights on the dash if that sender is there to warn you of a belt failure? Is there a fuse or other connector somewhere else? The belts are pretty new so it's not an immediate concern. Still... Any help is appreciated.
Old 06-03-2011, 08:22 PM
When the belt breaks the wheel moves closer to the motor and turns on a light. If held back by a zip tie the light will not come on. A cooling fan belt failure can now happen with no dash light warning.The engine will overheat very quickly. The alternator belt can break and the no charge situation will turn on the alt light. The sensor should be replaced asap or you could use the RS single belt conversion instead.
1980 911 SC 3.6 coupe sold
1995 993 coupe
1966 Mustang Shelby clone
1964 Corvair Spyder Turbo gone
2012 Boss 302
Old 06-04-2011, 07:31 AM
+1...A relatively inexpensive and simple fix...Well worth the cost, effort and time.
Old 06-04-2011, 04:48 PM
Paul K's Avatar
FWIW, I have had two sensor failures and zero belt failures. I carry a zip tie now for precisely that reason!
That said, +1 for replacing the sensor.
'85 Defender 90 V8 Station Wagon (mine), ‘16 Mini Cooper S Countryman All4, ‘79 Mini Moke Californian (hers).
'83 SC Coupe SOLD
'96 Carrera 4 Coupe SOLD
'89 Carrera Targa SOLD
Old 06-05-2011, 07:08 AM
Thanks. I snipped the tie and found the sensor doesnt squeak, but it does trigger the light even though the belt is just fine. I noticed the connector pin housing is loose. So I'll probably just replace the sensor. Seems pretty easy to do.
Old 06-16-2011, 11:59 AM
RETIRED
Joe Bob's Avatar
I converted to a single pulley.
2012 ML350 3.0 Turbo Diesel
Old 06-16-2011, 02:34 PM
mdowell's Avatar
When I converted to a single pulley, I took the sensor off and un-plugged it. I placed a metal clip in the end of the plug and taped it up, and zip tied it off and away. Don't miss it.
02 C4S
'78 911
'92 911 Cabriolet (Passed)
Old 06-17-2011, 05:24 AM
The sensor can be unplugged and removed easily. 5 mm allen bolt from the bumper side. 3 screws and a easy adjustment.
Old 06-19-2011, 12:29 PM
My fix
After reading all of the posts I ran a trial and error on the sensor. Easy to determine that it was the sensor, just jump the two connection points together and if the light goes out after 15 secs., its in the sensor unit. After removing the unit I opened it up and pulled the micro switch out, checking for any obvious signs of a short or abnormal wear. Then plugged the microswitch directly back into the receiver, and after holding the switch down the warning light went out. Simply adjusting the contact arm resolved the problem. Again, it takes about 15 seconds for the light to go off once the switch is activated, so patience is important when testing the options.
'95 993 Cab Daily Driver
Old 05-12-2013, 12:50 PM
si Banker's Avatar
964 fan belt
Two people on this thread mentioned a single belt system. I have a 1993 964 with air. Can I run one belt and still have air?
1987 911 Coupe
Triumph Trident Track Master
History is the lie we all agree to..........
Old 05-18-2013, 01:23 PM
si Banker's Avatar
964 fan belt
1987 911 Coupe
Old 05-18-2013, 01:36 PM
RETIRED
Joe Bob's Avatar
The conversion involves the pulley on the alternator only.
Old 05-18-2013, 01:56 PM
I am running single belt system with A/C in my 964.
Old 05-20-2013, 01:48 AM
