No low speed on engine cooling fan ?
New temp sensor. Resistor and fuse. Still no slow speed fan ? Took fuse out and jumped both positions. High speed works but no low speed ? This is a early 95 with old style engine cooling fan. Any ideas ? Thanks John
Old 09-16-2013, 01:45 PM
Relay problem? Burnt rear fan relays are common.
Cheers,
Tore
Old 09-17-2013, 07:03 AM
Sorry. I ment relay when I said fuse. New relay is in. Still no low speed. Thanks for responding Tore
Old 09-17-2013, 09:53 AM
There's not much left to have a fault then, I would start with tracing wiring faults. You could press the low speed relay (or short the terminals with relay out) and check that the resistor gets +12V when the low speed relay is on. (or shorted terminals) Then, test if this voltage is present on the other resistor terminal. (if not is the temp fuse in it tripped) Then see if the fan motor gets this voltage.
Cheers,
Tore
Old 09-17-2013, 11:14 AM
thanks Tore. I'll start looking
Old 09-17-2013, 11:31 AM
