ps In a 964
That's my car; I believe it was at the December Cars and Coffee.
I got a ps rack today and will be keeping the one that's on the car now. I will keep everyone up dated with pictures as the project unfolds. I am located in the DFW area and will have the work done by Mayo Performance. |
Please advise when Mayo will be doing the work. I work in the midcities area, i'd love to stop by and check out the conversion in progress.
PS conversion
The rack arrived yesterday. Tom at Mayo Performance got a rebuilt rack and it looks like it is brand new; the cost was $800. We also looked at MR-2 power steering pumps on e-bay and decided on one that was a power steering fluid/pump combination. Tom found a great place to mount the unit in the trunk on the right hand side in front of the fuel tank. Because the power fluid supply is part of the pump it has to be level .
As well as publishing it in EVO #108, it looks like Harry posted the topic in FerrariChat Lol at the backstreets photo - have driven those kind of roads in Majorca out the back of Polenca...utterly, utterly terrifying....especially at night in a recently collected hire car, as a passenger while (ex) Wife was blatting down them like she was remaking "C'était un Rendez-vous" |
parts
Here are some brackets that I made for the pump and master cyc. I have a brace in the trunk which I will use to hang the partshttp://forums.pelicanparts.com/uploa...1393530851.jpg
Parts
Here are some other photoshttp://forums.pelicanparts.com/uploa...1393531021.jpg
pump mount
This is how the pump bracket will work. The other parts are made to clamp on to the strut bracehttp://forums.pelicanparts.com/uploa...1393544904.jpg
si Banker, thanks for posting. Please keep updating.
Oleg |
So this is a 2nd-gen MR2 power steering pump? You have to install a separate power steering fluid reservoir?
This is the MR2 pump I had in mind when I made the suggestion earlier in the thread, and what most folks use for this type of conversion. It's from a 3rd-gen MR2 and has the reservoir built into the assembly. http://www.evdrive.com/prototypes/fi...steering_1.jpg |
Hey man, I saw you today over in Grapevine, by William D. Tate near Bone Daddy's.
Did you get your PS installed yet? |
Anything new???
WOW.. that is some beautiful machine work. You are very talented!
I hope that the instal goes smoothly. Stephen |
PW Steering
All the work on this project is done by Mayo Performance in Euless. Texas
The install of the power steering rack was a simple "bolt in;" there was a problem getting the correct hose fittings to connect the steering rack to the Toyota power steering pump. I will post a list of what fittings are needed tomorrow. The under side of the car does not look any different. One woould be hard pressed to tell the difference. Tom should get the pump mounted tomorrow. I will posr pictures then |
Power Steering
Tom finished the install yesterday afternoon and Saturday morning we took it on a 250 mile test run. It preformed fantastic. The steering effort at low speeds is greatly reduced and at highway speeds you don't know it is there. Parking the car is easy
The power steering pump is rubber mounted to the front of the tub where the tools are and the reservoir is from a 944 and is clamped to the shock tower brace. Tom put a 40 amp fuse in-line from the car to the pump. Everything is so sanitary you do not know it is there. Tom is sending me some pictures to post. I would like to this time to thank Tom and everybody at Mayo Performance for their help. |
Planning to do the same, any insights in the wiring side off things?,also does it makes much noise?, nice work on the mounting brackets.,enjoy, cheers, Stef.
here are some pictures
Pictures of the finished job
photos
more photos
more
| All times are GMT -8. The time now is 09:46 AM. |
