-   Porsche 964 & 993 Technical Forum (http://forums.pelicanparts.com/porsche-964-993-technical-forum/)
-   -   Adding Power Stearing To A 964 (http://forums.pelicanparts.com/porsche-964-993-technical-forum/785655-adding-power-stearing-964-a.html)
si Banker 12-05-2013 04:18 PM
How hard and expensive would it be to retrofit power steering to a 1993 RS America. I have Parkinson's and am loosing upper body strength
I don't think it would be hard to redo it back to stock. Also, I do not care what the changes do to the value because all a RS is is a 2wd drive 964http://forums.pelicanparts.com/uploa...1386292602.jpg
JordanPryce 12-05-2013 04:59 PM
It's not impossible, but it's not an easy job. Costs for the rack pump and all the related bits will run a few thousand plus installation. RSA racks are easy enough to sell, but I'd keep it with the car.
With the values of RSA's at an all time high, you should really consider selling it and buying a new Cayman or Boxster. They are amazing machines and much easier to deal with at low speed.
Vandit 12-05-2013 05:43 PM
Instead of retrofitting an OEM setup (which was never available on an RSA), consider an electronic power steering pump mounted in the front tub. There's a Porsche Motorsport pump that is popular for such applications and the third generation Toyota MR-S/MR2 pump is also popular. Basically you'd need a power rack off of a C2/C4 and do some fabrication of lines and give the pump power.
For example, using a Mercedes A-class pump.
http://forums.rennlist.com/rennforums/10470846-post96.html
http://forums.rennlist.com/rennforums/10485574-post114.html
metalracer 12-06-2013 05:56 AM
+1 On the Toyota pump. I have it on my C2 track car for weight and power savings and it works great.
Vandit 12-06-2013 06:02 AM
^It's on my "modification wish list"
Looking at the mess of OEM PS hardware and lines in the engine compartment annoys me. I can't wait to ditch all that.
si Banker 12-06-2013 08:24 AM
PS pump
Thanks for the great idea. I was not looking forward to dealing with all the Porsche parts. It sounds like what I really need is the rack of a C-2.
Thanks for the infof
kuehl 12-19-2013 07:21 PM
I recall the ratio is different on a 993 vs. 964, you may want to test drive
a 993 and see for yourself.
GeorgeK 12-19-2013 09:57 PM
Who here has first hand experience with the electric PS pumps?
I am pondering replacing my (leaky) setup with an electric pump, and would like more info about the level of assistance. The 964 steering is a light assist, not a buick style one finger steering job.
Spenny_b 12-21-2013 02:10 PM
These guys are getting a lot of press coverage over here in the UK at the moment --->
EZ Electric Power Steering
EVO magazine's Harry Metcalfe had them fit a system to his Countach, Octane recently fitted one to editor Crouchers classic Jaguar. All the systems have variable assistance via a potentiometer hidden from view - everything looks bone stock and is of course reversible should you want to sell the car on. No affiliation, but a pal of mine also makes very similar setups for rallying and racing Ford Mk2 Escorts, with great success.
HTH
Spencer
si Banker 12-24-2013 04:07 PM
steering rack
Any body have a c-2 or c-4 rack for sale
RS America 12-25-2013 02:17 AM
Thanks for the link Spencer. I just wrote them a email to get more information about their system. I'll post their reply when I get it.
I'm in Spain for the winter. If I get a reply from them I like, I'll drive my RS America to them in April or May for installation. I'll post about that too.
Driving around Europe with manual steering can sometimes be a real ***** on narrow medieval streets. Yesterday I was driving on some to get to a castle. There were spots where I was lucky to have 3-4 inches of clearance on the rear view mirrors. I was actually driving half on the sidewalk to get past some cars and no there isn't enough room to turn around. Backing up is scary. A wide body would be screwed.
http://forums.pelicanparts.com/uploa...1387970200.jpg
mreid 12-25-2013 04:15 AM
If you decide to go stock, I have all of the engine mounted components (pump, bracket, pulley, belt, etc.)
RS America 12-25-2013 06:04 AM
Googled EZ Electric Power Steering and found this. Real Interesting.
http://forums.pelicanparts.com/porsche-911-technical-forum/625956-installation-ez-electric-power-steering.html
Vandit 12-25-2013 03:00 PM
I don't think that setup is gonna work on a 964. The only place you'd be able to mount anything like that might be under the dash, and you can go look down there, it isn't spacious at all.
Vandit 12-25-2013 03:01 PM
si Banker: Was this you at Cars & Coffee this month?
https://fbcdn-sphotos-d-a.akamaihd.n...57866340_o.jpg
Dan J 12-25-2013 05:01 PM
I've installed power steering racks and 997 cup PS pumps on several RSA's
IMHO it's a great improvement and not terribly hard to do.
Due to the electric pump having lower pressure I think the steering feel is better then a standard 964. I like to use the 993 rack
Vandit 12-26-2013 05:21 AM
I believe you'd also need to open up the motor to swap out the camshaft since the RSA cam doesn't have the PS pump drive gear on the end.
Vandit 12-29-2013 01:19 PM
si Banker: you have PM
RS America 01-01-2014 12:30 PM
Got this email back from them. Sent a email to the shop in the Netherlands, think that would be the shop I'd go too.
Hi Don,
Thank you for your e mail, it sounds like you get around in your Porsche, where are you based? I only ask because our main workshop/ factory is in leerdam Holland. And they have converted a number of LHD 911's
The price varies between 1300-1400€ ex vat & fitting depending if it's a car with A/C
Or I am able to do the installation here in UK (Devon) for £2,350 fitted inc Vat
Kind regards
Mike Waters
EZ power steering UK
07967 439596
panzerfaust 01-03-2014 08:59 AM
si banker
if you do convert over to the power steering i would love to purchase the manual rack from you. or does anyone else out there have one for sale?
regards
pf
65rsr 01-04-2014 01:47 PM
Dan is the man. I drove an RSA with this set up at the track, it had a perfect, smooth, linear feel to it.
si Banker 01-06-2014 03:39 PM
ps In a 964
That's my car; I believe it was at the December Cars and Coffee.
I got a ps rack today and will be keeping the one that's on the car now.
I will keep everyone up dated with pictures as the project unfolds. I am located in the DFW area and will have the work done by Mayo Performance.
Vandit 01-06-2014 05:50 PM
Please advise when Mayo will be doing the work. I work in the midcities area, i'd love to stop by and check out the conversion in progress.
si Banker 01-08-2014 06:29 AM
PS conversion
The rack arrived yesterday. Tom at Mayo Performance got a rebuilt rack and it looks like it is brand new; the cost was $800. We also looked at MR-2 power steering pumps on e-bay and decided on one that was a power steering fluid/pump combination. Tom found a great place to mount the unit in the trunk on the right hand side in front of the fuel tank. Because the power fluid supply is part of the pump it has to be level .
Spenny_b 01-23-2014 03:11 AM
No problemo, glad you got a prompt response back from them. I have no idea how the steering feel compares to that using retrofitted OEM parts from other models, interested to hear any feedback (although I guess a lot of it will be very subjective without any direct back-to-back testing)....Certainly the likes of EVO magazine are very dialled in to chassis feel, with manufacturer electric power steering coming in for a lot of criticism from them over the last few years...so, I surmise that the EZ setup must be pretty damn good.
As well as publishing it in EVO #108, it looks like Harry posted the topic in FerrariChat
Lol at the backstreets photo - have driven those kind of roads in Majorca out the back of Polenca...utterly, utterly terrifying....especially at night in a recently collected hire car, as a passenger while (ex) Wife was blatting down them like she was remaking "C'était un Rendez-vous"
si Banker 02-27-2014 10:54 AM
parts
Here are some brackets that I made for the pump and master cyc. I have a brace in the trunk which I will use to hang the partshttp://forums.pelicanparts.com/uploa...1393530851.jpg
si Banker 02-27-2014 10:57 AM
Parts
Here are some other photoshttp://forums.pelicanparts.com/uploa...1393531021.jpg
si Banker 02-27-2014 02:49 PM
pump mount
This is how the pump bracket will work. The other parts are made to clamp on to the strut bracehttp://forums.pelicanparts.com/uploa...1393544904.jpg
perelet 02-27-2014 06:21 PM
si Banker, thanks for posting. Please keep updating.
Oleg
Vandit 02-27-2014 08:35 PM
So this is a 2nd-gen MR2 power steering pump? You have to install a separate power steering fluid reservoir?
This is the MR2 pump I had in mind when I made the suggestion earlier in the thread, and what most folks use for this type of conversion. It's from a 3rd-gen MR2 and has the reservoir built into the assembly.
http://www.evdrive.com/prototypes/fi...steering_1.jpg
Vandit 03-27-2014 04:02 PM
Hey man, I saw you today over in Grapevine, by William D. Tate near Bone Daddy's.
Did you get your PS installed yet?
mamut 04-18-2014 04:05 PM
Anything new???
two dot 04-22-2014 03:00 PM
WOW.. that is some beautiful machine work. You are very talented!
I hope that the instal goes smoothly.
Stephen
si Banker 04-23-2014 03:52 PM
PW Steering
All the work on this project is done by Mayo Performance in Euless. Texas
The install of the power steering rack was a simple "bolt in;" there was a problem getting the correct hose fittings to connect the steering rack to the Toyota power steering pump. I will post a list of what fittings are needed tomorrow.
The under side of the car does not look any different. One woould be hard pressed to tell the difference. Tom should get the pump mounted tomorrow. I will posr pictures then
si Banker 04-27-2014 09:29 AM
Power Steering
Tom finished the install yesterday afternoon and Saturday morning we took it on a 250 mile test run. It preformed fantastic. The steering effort at low speeds is greatly reduced and at highway speeds you don't know it is there. Parking the car is easy
The power steering pump is rubber mounted to the front of the tub where the tools are and the reservoir is from a 944 and is clamped to the shock tower brace. Tom put a 40 amp fuse in-line from the car to the pump. Everything is so sanitary you do not know it is there.
Tom is sending me some pictures to post. I would like to this time to thank Tom and everybody at Mayo Performance for their help.
mamut 04-27-2014 03:31 PM
Planning to do the same, any insights in the wiring side off things?,also does it makes much noise?, nice work on the mounting brackets.,enjoy, cheers, Stef.
si Banker 04-28-2014 07:51 PM
here are some pictures
Pictures of the finished job
si Banker 04-28-2014 07:54 PM
photos
photoshttp://forums.pelicanparts.com/uploa...1398743610.jpg
si Banker 04-28-2014 07:56 PM
more photos
Photohttp://forums.pelicanparts.com/uploa...1398743770.jpg
si Banker 04-28-2014 07:58 PM
more
photohttp://forums.pelicanparts.com/uploa...1398743887.jpg
