Air Conditioning Hard Line sizes
All,
In the process of fitting 964 air conditioning into my earlier car, part of a much larger ground up rebuild including fitting a 6-speed G50 and just ran into a bit of an issue with the hard lines running along the sill. The high pressure lines from the 964 fit all the way from the compressor to the receiver/dryer and the suction lines are fine except where on the 964 they turn up the side of the inner front fender into the trunk compartment (to the evaporator), and in the early car it needs to go under the pan and up through to the evaporator. Those last sections need to be fabricated, I was hoping to use aluminium for them but need to make sure I get the right line sizes. Can anyone help as far as what size those 964 AC lines are and what will fit? Are they metric sizes or US/Imperial sizes? Thanks Dennis |
![]() http://www.porsche.com/all/media/pdf/originalparts/en/E_964_KATALOG.pdf
1993 964 C2 still makes me smile Retired and work as needed as a pain in the **s. |
Thanks again. Dennis |
Tubing is aluminum.
Suction side is 19mm nominal OD High side is 13mm nominal OD 964-993 AC Components |
