Hi,
Well, I'm well into my 964 mania now that I've secured the right car. I've been reading some of the posts on Rennlist, and to be honest, I don't have a clue which direction to go in. I'm more curious now than when I started. I've seen on some of the post from Rennlist that these mods can add anywhere between 30hp - 50hp gains. I've also seen threads about rebuilding to 3.8, which out of the question now, but an interesting side note to the 3.8 build was that installation of "cam" only mods. Thoughts? Oh well, any PPheads in here that have done the SW, AFM, or MAR mods? If so: 1. Type? 2. Brand name? 3. Result? 4. new HP ratings if any? 5. Problems? 6. Cost? I'm probably getting in over my head as I haven't even taken possession of the car yet, but I'm fired up on the idea of modding the car for more performance w/o spending a tremendous amount of money, e.g. engine mod/rebuild. HB
Current: 1990 964c2 Grand Prix White: lowered, Big Reds, Big Fun! 1971 911 T Targa Signal Yellow (summer joy) Past cars: 1970 911T Yellow, 1983 928, 1972 911 Targa emerald green |
Neerlandofiel
horsepower costs money.
The thing about the 964 is that it really rewards good driving. I wouldn't spend a dime on upgrades until you decide if you really need them. I enjoy driving the 964 more than I ever did my 408hp 997 GTS
1990 944S2 Baltic Blue 1,960 original miles 1989 944S2 Guards Red 82,000 miles Gone: 06 Exige, 08 Cayman S Sport, 67 911R Hotrod, 09 Cab, 93 RSA, 91 964, 13 Boxster, 15 Macan S, 05 Elise, 00 M-Coupe, 71 914-6, 75 Carrera, 11 997 GTS etc.. |
I agree with Jordan. The 964 is such a wonderful beast out of the box that even in stock form, you'll be a able to drive it like you stole it!
A lightened flywheel, Steve Wong chip and a cup bypass may increase your awareness to the car, but even those subtle mods are more than enough. Cheers, Last edited by Beetle88; 04-13-2014 at 07:18 PM.. |
Changing to an open exhaust (993 headers) and a chip is what probably gives you the most "bang for the buck" if you want to modify things. The light flywheel could cause drivability issues (stalling) - not sure that it really makes sense.
Then there is always making the car lighter (stripping interior parts) if you really need better power/weight ratio. Ingo
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430 I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!! How about a NoBadDays DualChip for 964 or '95 993 |
Wong Chip can address the stalling issue with the lightened flywheel.
Cheers,
Mauricio 3 Pedal Posse People Passion Places www.3pedalposse.com IG: 3pedalposse |
I don't think I've seen legitimate evidence that the stock AFM is a bottleneck.
'90C4 |
as above SW chip prevents it from stalling. picked up 19rwkw with better exhaust and a lightweight flywheel on a similar car |
cams pretty much the same, main difference is ramps to accommodate hyd lifters valves same, 993 has 8mm stems 964 9mm stems ports 993 1.5mm larger intake & 1mm larger exhaust CR same metering 964 barn door mechanical, 993 hit wire electronic exhaust 964 crossover, 993 dual hp 964 250@6100, 993 272@6100 torque 964 228@4800, 993 242@5000 You can see that they went to a lot of trouble to open up the intake/exhaust flow path. while there is no # that separates out the metering it certainly contributes to improved flow
No doubt, but if swapping the stock afm in a 964 released power people would be all over it; the newest of these cars is 20 years old and the 'easy' mods have all been explored. The fact that every 964 owner isn't clamoring for an AFM replacement suggests that in the absence of broader changes there's not much to be gained by this single modification.
OP: Get yourself a g-pipe and drill your airbox lid
'90C4 |
I have an Autothority hot wire MAF and K&N filter which replaced the barn-door. Unfortunately, this setup will not work with a stock Steve Wong chip.
I can't quantify any improvement due to the intake swap. I have a dyno measured gain of 18 HP and 18 pound-feet of torque, however this included the inlet, Fabspeed dual exhaust and cam timing changes.
LouZ '90 C2 TIP '08 Cayman S |
I don't know if you guys have searched Rennlist forums, but there is a great debate on this issue. I wanted to get an opinion from this site because I've been coming to PP for some time now.
HB
On a stock 964 I think the bang for the buck mods for acceleration are:
- Freer flowing exhaust - best case being a full header exhaust, the stock 964 headers don't flow very well. - Drilled airbox - nearly free and 2-3 hp (plus the intake sound when the flap opens is glorious) - LWFW and Chip - I felt it was a pretty dramatic difference in overall feel of the car, and a chip is required - Gears - big difference in acceleration when you stay in the power curve with every shift - Motec upgrade - expensive but big power increase relative to everything else Just my 2 cents worth!
KW V3, B&B exhaust, SW chip, RS clutch/flywheel, Walrod & Powerflex bushes, Rennline camber plates, RS heat bypass, RS fog ducts, RS engine mounts |
See here 'No Bad Days' performance chip - first impressions for what a chip can do on a 964: 17HP. It is a direct comparison. The data was taken on the same day, same dyno back-to-back with the switch in stock position and then in chip position.
The car had B&B headers (better flowing than stock exhaust) but no other major modifications.
