964 cam housing holes???
hi All, I'm rebuilt my 964 engine (M01/89 WHIThout heads gaskets..) on the cam housing there are two holes that do not know what they are what they are?
oil breather?
lubrication chain ramps?
on the manuals / drawings also on the net I have never seen these holes....
thanks ALL for the answers
dan
---the difference between insanity and genius is success--
Old 01-02-2015, 08:20 AM
----help!
Old 01-04-2015, 12:56 AM
Certified User
billjam's Avatar
Dan,
This probably doesn't help, but my 1992 M64/01 engine doesn't have those holes.
Check which engine type is stamped on the case where the temp sensor is sitting in my picture. It should be M64/01 for all 89-94 964's unless it is a tiptronic, RS or turbo.
Bill
1988 Carrera - 3.6 engine with ITBs, COPs, MS3X
2024 Macan S
Day job ... www.jesfab.com.au
Memories: '68 912, '72 911T, '80 911SC, '84 911, '85 930, '86 930, '87 911, '21 Macan S
Old 01-04-2015, 02:54 AM
hi billjam
and very thanks!
yes my engine is M64/01 first series 1989, I'am to rebuilt for fit on 3.2 body....
the problem is what are those holes, I would close the chains and do not know whether to leave the holes so or cap them and I do not remember when I unmounted if they were already empty))
I see that you do a transplant 3.6 ... there are many 3d ... but I'd like to share some information
very thanks! GRAZIE!
Old 01-04-2015, 05:25 AM
Tom '74 911's Avatar
Hi Dan,
I had my '90 3.6L engine rebuilt last winter after doing the tear-down myself. Here are a few photos I took where you can see the same holes. Hard to 100% certain, but it looks like they are left as-is on mine? I don't remember noticing them... do they go all the way through?
Tom
'74 911 Red Sunroof Coupe, 3.6L, etc...
'76 912 Yellow SPEC 911/911CUP
Old 01-04-2015, 06:40 AM
hi Tom and thanks!
Apparently not actually go anywhere....I do not know if you leave them open or close them...close them with Loctite or similar
Old 01-04-2015, 10:56 PM
crg crg is offline
dan
i'm currently rebuilding my 89 964 as well. I have those same holes, there is nothing I can think of that would go into those. mine will be left as is...
Old 01-05-2015, 02:36 PM
Try asking the smart people in the Rebuilding forum- you may be more likely to get an answer there, some of the contributors have seen the inside of lots of pcar motors.
'90C4
Old 01-05-2015, 04:24 PM
I'm rebuilding an 89 as well, I'm not sure if my engine has had any retro fit from Porsche regarding the cylinder head gaskets. If not I was not planning to upgrade assuming there's nothing warped.
Is there a better idea, what are you guys doing??
Old 01-21-2015, 05:13 PM
