-   Porsche 964 & 993 Technical Forum (http://forums.pelicanparts.com/porsche-964-993-technical-forum/)
-   -   compression test (http://forums.pelicanparts.com/porsche-964-993-technical-forum/854274-compression-test.html)
kelboni 03-02-2015 06:09 PM
compression test
I have my engine out of the car, took the plugs out and connected a compression gauge to #1 then # 2 after five or six hand cranks I got a reading of 90 psi on both cylinders. I gave up going any further. Any ideas how i can get a more accurate reading? Thanks
johnsjmc 03-03-2015 05:40 PM
Reinstall the starter and jump it with some battery cables. Hold the throttle open while cranking.
You could do a leakdown instead.
Derek911 03-04-2015 08:40 AM
^ what he said. You are going to have to bump the engine or do a leakdown. Leakdown is the better test anyway.
