Alignment Question
:confused:
Will soon need alignment for C2S with pss10 coilovers. First I will set ride height, understand that any alignment changes once ride height is set will change alignment. I need to decide which wheels and tires should I use when alignment is done. Tires on each will be different brand but same size. Also if I put on slightly different wheels and tires i.e.. (sized) will that change the alignment. |
different wheel and tires sets won't measurably affect alignment
With the ride height adjustability of PSS10 You should consider setting/checking corner balance when setting ride height and before you align.
| All times are GMT -8. The time now is 06:32 AM. |
