Alignment Question
Will soon need alignment for C2S with pss10 coilovers. First I will set ride height, understand that any alignment changes once ride height is set will change alignment.
I need to decide which wheels and tires should I use when alignment is done. Tires on each will be different brand but same size.
Also if I put on slightly different wheels and tires i.e.. (sized) will that change the alignment.
Old 03-06-2015, 04:31 PM
Bill Verburg's Avatar
different wheel and tires sets won't measurably affect alignment
Bill Verburg
Old 03-07-2015, 06:29 AM
With the ride height adjustability of PSS10 You should consider setting/checking corner balance when setting ride height and before you align.
1980 911 SC 3.6 coupe sold
1995 993 coupe
1966 Mustang Shelby clone
1964 Corvair Spyder Turbo gone
2012 Boss 302
Old 03-07-2015, 08:12 AM
