2 questions I've been asked that I have no answer for
Hi,
Q1. Do you know if it has a crank and camshaft position sensors? Q2. If so, how many teeth are on each? Background info. 1992 german engine in a 1990 RHD 964 C2 manual coupe. Questions asked by a MoTeC rep. that's suggesting a M800 ECU. Thanks for your help, John |
There is a crank position sensor, some times called a flywheel speed sensor.Access is behind the drivers side rear tire. There are no teeth on the sensor. Perhaps you are referring to the flywheel teeth? The gap for the sensor is 1 MM.
there is also a Hall sensor in the distributor that serves to identify cylinder #1 firing |
I knew I'd get an answer. Thanks. John
| All times are GMT -8. The time now is 04:16 AM. |
