964 3.6 A/C & engine bracket delete?
I have seen that many just cut their A/C bracket & put it back on and also use the original engine bracket as well. Why? Easy fix?
Must i use these or can i make my own & just use the original mounting points? Dropping a 3.6 in to a 911 from -71 will probably not allow the use of these brackets anyway. I haven't come so far just yet. But even if it will fit the plan is to make a custom bracket & delete the two original ones. Any thoughts from the more experienced crowd :) http://forums.pelicanparts.com/uploa...1433534034.jpg |
you can use the oe RS engine console to eliminate the AC mount, these were unavailable for a long time but I believe that they can be purchased from Porsche again or you can cut the AC mount off, 2 ways to do it keep the upper bolt or not http://forums.pelicanparts.com/uploa...1433799482.jpg oe RS console http://forums.pelicanparts.com/uploa...1433799526.jpg oe RS console w/ oe RS lower single sheeve pully http://forums.pelicanparts.com/uploa...1433799596.jpg different motor same parts http://forums.pelicanparts.com/uploa...1433799878.jpg cut console retaining the upper bolt, stock 3 sheeve lower pulley, RS upper pulley http://forums.pelicanparts.com/uploa...1433799956.jpg |
Why go through all that hassle?
Just use the console and mount from your year. It bolts right in. Here is the 95 3.6 in my 74 911. Easy. http://forums.pelicanparts.com/uploa...1433811715.jpg |
| All times are GMT -8. The time now is 09:54 AM. |
