-   Porsche 964 & 993 Technical Forum (http://forums.pelicanparts.com/porsche-964-993-technical-forum/)
-   -   Worn front sway bar drop links (http://forums.pelicanparts.com/porsche-964-993-technical-forum/877118-worn-front-sway-bar-drop-links.html)
993buyer 07-31-2015 05:29 PM
Hi all, How difficult is this to replace these myself? Or, do I need specialized tools to do this?
What about alignment after replacement? Thanks!
heliolps2 07-31-2015 08:06 PM
me too
Bill Verburg 08-01-2015 05:04 AM
You can DIY, they do not affect alignment
The hardest part is getting room to screw into the wheel carriers
http://forums.pelicanparts.com/uploa...1438430653.jpg
993buyer 08-01-2015 10:07 AM
Should I just replace these or are there other bushings/parts that I should replace at the same time...I just replaced the wheel arm bushings and shocks/struts...
Quint
Bill Verburg 08-03-2015 11:06 AM
all the bushe should be replaced after so many years, the '95 are now 2 decades old
for best combination of ride and performance
use Elephant sport bushes on at least the trailing legs of the front A-arms, on the leading legs too for best results
use RS rear A-arm and KTs arms(Elephant sport bushe can also be used here), use normal camber and toe arms and bushes, though the toe arms can be stiffened w/ either sport bushes or even mono-balls if the car is tracked.
heliolps2 08-05-2015 08:32 PM
Ok. But how do get it out , with the hub on the car
