rlrussel's Avatar
Oil spray tube 964-101-020-00
My 964 is apart and I would like to change the oil squirters that spray the bottom of the pistons. It had some neglectful maintenance over the years
Can't seem to find this part on this side of the ocean. I found four from a Porsche dealer in Denver but every place I call seems to be out.
I have heard that the 933 valve will work with some machining of the engine case. Any one know? Part number?
Old 09-08-2015, 11:04 AM
Bill Verburg's Avatar
there is also an oversize version 964.101.020.50
the 993 versions are 993.101.018.51 and .60(oversize) the 993versions are 11mm bigger than the 964 versions
Bill Verburg
Old 09-08-2015, 12:00 PM
