How many hours for a shop to replace all 4 rotors on a 993
Anyone know what the book time is for this? Thanks
Old 09-05-2015, 03:37 PM
Simple job for sure. The effort is in removing the calipers (2 bolts per caliper) and the hold down screw(s).
But all of this requires a brake job level of effort and the bleeding / replacement of brake fluid.
Also front caliper bolts are supposed to be replaced, not reused.
A competent wrench should be able to get this all done (full brake job w/ rotors) in 2 - 3 hours of labor, but the parts will be the biggest price point (pads, sensors, squeal pads, fluid, rotors).
Old 09-06-2015, 05:49 AM
Opo Opo is offline
Labor should be no more than 4 hrs , parts will depend if it has the Bg Reds or just normal C2 brakes .
Old 09-06-2015, 07:43 AM
Functionista
manbridge 74's Avatar
I believe we get paid 3hrs for this.
Jeff
74 911, #3
I do not disbelieve in anything. I start from the premise that everything is true until proved false. Everything is possible.
Old 09-06-2015, 07:50 AM
