How many hours for a shop to replace all 4 rotors on a 993
Anyone know what the book time is for this? Thanks
Simple job for sure. The effort is in removing the calipers (2 bolts per caliper) and the hold down screw(s).
But all of this requires a brake job level of effort and the bleeding / replacement of brake fluid. Also front caliper bolts are supposed to be replaced, not reused. A competent wrench should be able to get this all done (full brake job w/ rotors) in 2 - 3 hours of labor, but the parts will be the biggest price point (pads, sensors, squeal pads, fluid, rotors). |
Labor should be no more than 4 hrs , parts will depend if it has the Bg Reds or just normal C2 brakes .
Functionista
I believe we get paid 3hrs for this.
Jeff 74 911, #3 I do not disbelieve in anything. I start from the premise that everything is true until proved false. Everything is possible. |
