964T rear brakes on 993C2?
I have a set of drilled 299x28 rear rotors that came off a 96' 993C2. I realize these are 964T rotors, what would those be doing on the rear of a 993? Is that a common swap?
They are not interchangeable are you sure this is what you have?
Anthony PCA affiliate '77 member '83 '90 3.8 RS tribute, 91 C4 converted to C2,'93 964 C2, '93 928 GTS M '94 Turbo 3.6, '15 Boxster GTS M,16 GT4,23 Macan GTS, Gone worth mentioning '71 E '79 SC, '79 built to '74 3.0 RS tribute (2390 # 270 hp), '80 928 euro 5 speed, '74 2.0l 914, '89 944 S2,'04 Cayenne TT '14 boxster, '14 Cayenne GTS 14 Cayman S, 18 Macan GTS many others |
Are you sure the calipers on the 993 were original? That seems like a very tight fit (width) on the 993.
