DME control Unit Part Number Cross Reference
I have a 1990 3.6 installed in my 911. The brain has part number 964.618.124.03.
I bought another 3.6. It came with a brain with part number 911.618.124.01. Is this the correct brain for a 3.6 or did I get short changed? Does anyone know the differences between the two part numbers? Thanks.
Old 01-13-2016, 03:26 PM
group911@aol.co's Avatar
The earlier 964's had a DME with a 911 part number. I've used early in late and late in early and can't tell much difference. Are both of your engines aluminum intake versions?
Thanks,
Bob
group911@aol.com
Old 01-14-2016, 06:32 AM
My concern was that the seller provided me with a brain from a 3.2 rather than a 3.6. Since, I have compared a 3.6 brain to a 3.2 brain and see that the enclosures have different dimensions so I have concluded that I do have a 3.6 brain. With your input confirming interchangeability I guess I am now OK. Thanks for your help.
FYI the brain with the 964 PN came with a motor with plastic intakes and the one with the 911 PN came with a motor with aluminum intakes.
Old 01-14-2016, 10:22 AM
