piston carbon deposits
I cleaned the carbon deposits from my 993 pistons and now I need to figure out something that would prevent it in the future. I was told to either polish the surface or ceramic coat it. The polishing is very time consuming and ceramic coat is about $20/piston at Pristine Powder Coating is located in Denver, Colorado .
Here is where I am at now - clean surface. Any comments?
Old 05-25-2016, 11:42 AM
prschmn's Avatar
Ceramic coating generally not well advised-piston will run cooler causing more skirt wear.
since it won't expand as much as it needs to.
Drive harder------
Mark
www.exotechpower.com
1981 Targa-messed with. 91 C2 supercharged track rat
Radical Prosport-irritates the GT3 guys
40 years of rebuilding services
Old 05-25-2016, 04:24 PM
I was looking for that kind of reasoning - thanks! Correcting porsche engineers is almost always a bad idea. I guess back to 600 grit sand paper and buffing wheel...
Old 05-25-2016, 06:40 PM
prschmn's Avatar
Just DO NOT polish the skirts-some texture is designed in for oil retention.
Mark
Old 05-26-2016, 02:14 AM
Nine9six's Avatar
Here is some info...
https://www.google.com/url?sa=t&source=web&rct=j&url=http://swaintech.com/wp-content/uploads/2012/03/Performance-Coating-News.pdf&ved=0ahUKEwi23ImNovnMAhUG4GMKHYaFCMcQFggeMAE&usg=AFQjCNEw9CIa4XOTIaTDwhoGTePcrJWmdA&sig2=jW_L2m4HShKlZ-kzX2gDfg
If it flows, it goes. If its smooth, it moves. Any questions?
96 993 C2 (Current)
87 911 Factory Turbo-Look Cab (Sold)
85 911 Factory Turbo-Look Targa (Gone)
Old 05-26-2016, 07:08 PM
I am getting there - steel wool grit 0, 500grit, 800grit, 3m rubbing compound - lens buffing kit. One done 5 do go :-)
Old 05-27-2016, 06:53 AM
I ground and polished the sides of the connecting rods in my old hotrod before having them shotpeened. I used 3M Roloc discs in an air powered right angle die grinder. I used the Grey, then Burgundy, then Turquoise discs and they got them pretty shiny. Try this if you want to speed up the polishing process.
Eric
1992 911 C2 Cabrio, Amazon Green
Huntington Beach, CA
Old 05-27-2016, 08:29 AM
prschmn's Avatar
Re 9962 info-good info but doesn't exactly apply to air cooled pistons and cylinders.
In a water cooled engine it's not uncommon to have .004-.005 cylinder to wall
clearance-cold-it's needed because the Aluminum has nearly three time the coefficient expansion
rate relative to steel so keeping the piston cooler allows a much smaller cold clearance-
good for skirts, etc.. But as the piston and cylinder in an air cooled engine such as a 3.6
are of similar materials the cold clearance is greatly reduced and not allowing the piston
to heat as planned means an excessive hot clearance. In order to run a coated piston crown
AND get good hot clearances you'd need to run an at least near zero if not an interference fit when cold. I expect the result of that would not be pretty.
Mark
Old 05-27-2016, 04:36 PM
prschmn's Avatar
PS I do like Swain coatings when needed-been using them for years.
Mark
Old 05-27-2016, 04:39 PM
Does polishing them that much increase power, or does it make them run more efficiently?
Old 06-01-2016, 11:53 AM
I think the carbon will not stick that much to a smooth surface.
Old 06-01-2016, 01:56 PM
