jc jc is offline
Question low beam relay location on a 996?
Hi,
I posted this on the boxster board but had no response, maybe a 996 owner can tell me...
My '99 Boxster headlights are looking very dim when on low beam, but the high beams are fine though. Fuses look good, so I'm thinking its the relay - only I can't find the relay for the headlights. I checked the relays that are located in the driver footwell above the fuse panel by pulling them one by one to see if any had an affect on the lights. None did. Can anyone point me to the location of the low beam relay(s)?
Cheers,
jeff
'88 Carrera Coupe,
Goes to 11
Old 12-04-2002, 09:54 AM
jc jc is offline
more..
I looked at it again and if I pull the fuses for both head lamps, they have no effect, ie both head lamps are on (dimly) when the light switch is on. Does this ring a bell for anyone?
Regards,
jeff
'88 Carrera Coupe,
Goes to 11
Old 12-06-2002, 04:48 PM
ischmitz's Avatar
Send a message via Skype™ to ischmitz
Jeff.
Shouldn't that be covered under warranty on a 99 model? I would opt for a short trip to a dealer and have them check it.
If they have to keep the car for the day you might even get free detailing... (At least that's the case at my dealer)
Ingo
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430
I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs
Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!!
How about a NoBadDays DualChip for 964 or '95 993
Old 12-11-2002, 11:35 AM
Of course, what might have happened is that both low beam bulbs (H7) have blown???? Anyway it's warranty, take it to the dealer.
From November 2012; Precision Porsche Specialist
Sussex UK, +44 (0)1825-721-205
2001-2012 Gerber Motorsport Inc. 206-352-6911
07.15.06 1996 Ducati 900SP. Suprisingly enough, it's red
08.16.09 1999 Kawasaki ZRX1100. Green.
Old 12-11-2002, 04:33 PM
Don Haney's Avatar
I checked all the manuals we have for the Boxster and 996, but strangely Im missing the electrical sections on each model??
In the supplement I did find that the fuses are listed as below.
No listing for a relay.
Row A
Fuse # 1, 2, 9, 10
Hope this helps,
Don
91 C2
Don Haney
don@pelicanparts.com
888-280-7799 Ext 305
1991 C2 Tip - Sold
Old 12-12-2002, 12:43 PM
That is because there is no relay for US. See my post on the Boxster board.
The poster is confused, or has a bad switch, or a bad ground. In that order.
Jeff
Old 12-12-2002, 04:23 PM
jc jc is offline
a bright finish
Thanks to all who replied.
As it turns out, both low beam bulbs were blown. What are the odds? Pretty good I guess.
Cheers,
jc
'88 Carrera Coupe,
Goes to 11
Old 12-12-2002, 07:35 PM
