-   Porsche 964 & 993 Technical Forum (http://forums.pelicanparts.com/porsche-964-993-technical-forum/)
-   -   EZ69 Solution? 964 Turbo Ignition Module (http://forums.pelicanparts.com/porsche-964-993-technical-forum/928847-ez69-solution-964-turbo-ignition-module.html)
Reanimotion 09-22-2023 08:52 PM
Originally Posted by Cobalt (Post 12094469)
info about the processor chip in your ez68
https://pdf1.alldatasheet.com/datasheet-pdf/view/66066/INTEL/8751H.html
The 8751H is an EPROM version of the 8051AH.
It has 4 Kbytes of electrically programmable ROM which can be erased with ultraviolet light.
Is fully compatible with the 8051AH but incorporates one additional feature: a program Memory Security bit that can be used to protect the EPROM against unauthorized readout.
The 8751H-8 is identical to the 8751H but only operates up to 8 MHz.
Reanimotion 09-23-2023 12:36 AM
Fourth revision has been approved and sent to fabrication.
Cobalt 09-23-2023 07:05 AM
Thx
Neil Harvey 09-24-2023 07:23 AM
I picked up these units years ago when ANDIAL shut down. I sold one of the units To Maverick over on rennlist. The two are marked EZ68 and have the number 58 on them. I am assuming these were used on the Brumos #58 car at some time.
I have no idea what the chipsets are and how to read them but if the remaining unit I have will help the cause I am happy to lend it. I do recall the unit I have did not work as well as the second in his 3.3T so it might not be anything that can help.
Neil
Do you recall these and f they might be of help?
I believe adapters were needed to make the plugs work.
http://forums.pelicanparts.com/uploa...1695406745.jpg
Thank you. I know nothing about the factory part. I do remember this engine project when I worked at Andial. However, those units were delivered from Germany and we had nothing to do with their inception.
Any time you add aftermarket parts you run into plug and wiring issues. In this case we had no other way. It solved a problem and worked well. The customer was happy as his car sat for over 1 year while a solution was found. We solved the problem in days and he was very grateful.
Reanimotion 09-28-2023 06:40 AM
Remember anyone saying "math might save your life" ?
I guarantee it wasn't an engineer.
defining accurate pin placement for the connectors involves this :-
https://www.researchgate.net/profile...-trapezium.png
mysocal911 10-01-2023 08:49 AM
What has happened here, http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/820323-digital-wur-plus-frankencis.html lately?
Reanimotion 10-01-2023 09:26 AM
FrankenCIS is still going strong out there in the real world, not much activity on the Pelican thread though.
What we are doing for the Mercedes folks with the EZL, will pretty much become the new version for them.
No Microsquirt and direct control (optionally) for the KE-Jetronic on top of the EZL ignition.
Reanimotion 10-02-2023 04:41 AM
http://forums.pelicanparts.com/uploa...1696246820.JPG
mysocal911 10-02-2023 06:19 AM
What's the link to the product description and availability?
mysocal911 10-02-2023 06:29 AM
Originally Posted by Reanimotion (Post 12100439)
Surely, you'll be adding knock-control thru the multi-connector, right?
Reanimotion 10-02-2023 08:59 AM
The EZL is still under development, but the primary requirements in order of importance are :-
  1. Plug and play - no wiring changes
  2. Looks OEM
  3. Ignition tuning
heliolps2 02-08-2024 07:49 PM
  2. Looks OEM
  3. Ignition tuning
As a 965 owner, I so excited to see what you come up with. I just used my last spare
Please PM once you have working' unit available.
Helio Lopes
heliolps2 02-08-2024 08:42 PM
Many people on Reenlist 964 turbo owners that use these units are mostly on that site. It would be good for the 965 Ez69 owners to see what you have developed. You will have great success there.
Please start a thread there. You will have plenty of customers there.
Helio
Reanimotion 02-08-2024 09:14 PM
Shall do,
The Hardware is running on the bench and the firmware core is functionally complete.
The design and implementation is closely following OEM features and requirements with a few modern tweaks to enhance reliability and protection.
Case and connectors are not yet finalised. As we back-and-forth with suppliers, specs have been refined to match manufacturing realities.
So we are frequently deciding on little details, and then rinse-repeat.
Also, everyone, please hang on to your dead ones as we might also be able to do an exchange program for the EZ69 case.
The schedule has us well placed for in-house vehicle testing of two different prototypes by early April, so maybe mid-year for one or more hand-built units to escape the lab.
poor little naked one on my desk now :)
http://forums.pelicanparts.com/uploa...1707455603.jpg
and our calibration software connected
http://forums.pelicanparts.com/uploa...1707454966.JPG
heliolps2 02-09-2024 07:46 AM
Originally Posted by Reanimotion (Post 12190185)
Shall do,
Thank you for the update. This is so exciting. We appreciate you hard work! Are you going to start a thread on the Pelican 911 turbo and Reenlist 964 Turbo forum?
Reanimotion 02-10-2024 07:55 PM
Thanks,
As for a dedicated thread, here or elsewhere, I want to make sure we actually have a viable solution first.
heliolps2 03-23-2024 09:32 AM
Originally Posted by Reanimotion (Post 12191415)
Thanks,
Hi, I hope you had a few productive few weeks, any updates?
Reanimotion 03-23-2024 11:57 PM
Hi,
Nothing definitive, physical aspects of case and connectors are the current focus.
As expected, bespoke parts are required for 95% of the module.
Still on track for physical on engine beta testing mid to late April (Mercedes)
wicks 04-27-2024 03:07 PM
WOW. I had no idea this was happening. Holding onto spare cases for sure.
You might also be able to use MBZ cases from dead units as they are so plentiful. Perhaps there are differences on the vac hose sensor though, maybe that's also being replaced...
GENIUS WORK pls carry on!
Reanimotion 04-28-2024 12:38 AM
the crazy continues...
http://forums.pelicanparts.com/uploa...1714286326.jpg
CNC finished upper housing from a formed blank of PA12-F nylon allows the 3d features such as the manifold pressure port and programming connector, the CNC steps then work with the required 0.5mm wall thicknesses between the main connector pin voids and keyways.
Reanimotion 07-08-2024 04:50 AM
CAN-BUS integration with dedicated modules where practical.
https://www.plex-tuning.com/wp-conte...MALLER_RFL.png
https://www.plex-tuning.com/products/plex-knock-monitor-v3/
heliolps2 07-09-2024 03:48 PM
Wow! looks amazing. Thank you soooo much for all your hard work
Helio Lopes
tripleJGTR 11-20-2024 08:48 PM
Any new updates ?
Reanimotion 11-20-2024 10:14 PM
development progressing,
http://forums.pelicanparts.com/uploa...1732166090.jpg
heliolps2 11-26-2024 03:16 PM
Originally Posted by Reanimotion (Post 12361688)
Wow ! those are sexy. Great work
Please email me once you you have a working unit ready to test or sell. i own a 1992 964 turbo stock with a RUF wastegate spring of 0.9 bar. I assume those work on bothe the 3.3 and 3.6 turbo's ? I live in the Washington DC area. contact info heliolps2atyahoodotcom.
Thank you kindly
Helio
wicks 11-27-2024 07:34 AM
Amazing - I don't mind them being in your case design instead of inside an old B case.
Are there any heat or grounding concerns as with the originals?
Will be curious about the programming as well, though I have a stock car with just free flow cats.
Yes the 3.3 and 3.6 964 turbos were a different map, assume you're making these mappable to all the various specs of cars they were used in to have the largest market.
heliolps2 01-13-2025 10:01 AM
Happy new year to all, I also don't mind them being in your case design instead of inside an old B case. your units look GREAT !
Can't wait to buy one for my 3.3
DirkF 03-31-2025 02:10 AM
Hello, thanks for working on this problem. I have a 964 3.3 Turbo that's been sitting for two years because there's no 1969 version available. If anyone can help me out for a while, that would be great. Otherwise, I'll have to wait until the replica is available.
Thanks, Dirk
myfisch 04-03-2025 05:12 AM
Thanks, Dirk
If your car is sitting for 2 years, I will help you you with a refurbished module.
Best Regards
mysocal911 04-03-2025 08:45 AM
Best Regards
What does a "refurbished module" mean?
myfisch 04-05-2025 11:30 PM
We are able to repair 90% of this units and these are in stock for exchange
Regards
mysocal911 04-06-2025 10:15 AM
Regards
Please post some images of "repaired" units. Thanks
heliolps2 04-15-2025 10:27 AM
Regards
Hello Thomas, I'm sorry i didnt recognize you. I sent you a message. Please email as well. I need a EZ69-01 for my 1992 965. I heard the EZ69-02 will work on the 3.3, Is that true?
myfisch 04-15-2025 11:08 AM
02 runs I. 3.3 but it works with a different ignition angle and because of no knock detection on this engine it’s risky.
Iam happy that you still own the car with my engine and trans pack✌️
heliolps2 04-15-2025 12:25 PM
Yes, I'm very happy with you engine and trans for my 965. Read all about it here . the last page is the best.
https://forums.pelicanparts.com/911-930-turbo-super-charging-forum/886233-even-trade-92-965-my-97-993-cab-hmmmm.html
https://rennlist.com/forums/964-turbo-forum/990555-traded-my-993-cab-for-92-965-a.html:rolleyes:
I had someone contact me about your shop, I told him that I done business with you and it was a great experience. and to trust you. Thank you again. Just to let you all know, I bought a complete 965 engine and trans from Thomas at FSR Auto sport and had him ship it to me in Virginia from Germany, by air, it went smoothly. I can't say enough about the experience.
Check out his shop in the Porsche motherland, It's amazing . I highly recommend FSR Sport Auto https://www.fsr-sportauto.de/ and follow him onhttps://www.facebook.com/search/top?q=fsr-sportauto or https://www.instagram.com/fsr_sportauto/
Thomas please let know how to get a EZ69-01 as soon as possible please send the info via email. heliolps2atyahoo.com or message me
stre 04-15-2025 03:30 PM
It’s a tricky one for sure! If you’ve been searching for months with no luck, you might have already seen that new ignition modules are pretty scarce. A few people have had success sourcing used ones, but you’re right, the physical difference is minimal, so using the MB (96560270602) could work as a temporary solution, especially if you can match the pinout and connector.
mysocal911 04-16-2025 09:32 AM
Negative going trigger pulse!
drako13 05-05-2025 09:28 AM
Greetings,
I would also like to know about these repairable units. I have a 964 3.6 turbo in my shop and can't seem to find a solution to these modules
Cobalt 05-06-2025 04:27 AM
I have 2 spares in case you run into a dead end but it is pricey.
Bastin 05-08-2025 09:10 AM
I've got two spare units lying around for my '94, and Porsche charges an arm and a leg for rebuilt ones - like $3000 plus a $900 core charge. These would be a huge score if they work, If I can get functional ones for under $100, that's a massive savings. Fingers crossed
