There are sites claiming to sell them however Porsche has no inventory and I suspect if you try to buy them they will tell you they can't get one. |
Will the 3.3T and 3.6T EZ69 come in different versions? Thought there were some key differences between the two. Maybe a single unit with multiple maps?
Any updates on the development on these units?
Prototypes are currently undergoing durability testing, and although indications are we have a viable product from an engineering viewpoint, there is still much to do.
Next step for us is the pre-production evaluation phase, and concentrating on manufacturing viability. e.g. refining the upper case to eliminate several of the CNC machining steps required for the prototype phase. The tiny potential market for this and the physical complexity and dimensional tolerances of the module have this silly project jammed well and truly in the "must be near perfect or don't even try" zone. |
I’ll take one as well! Much needed as my 94 turbo will die if you shift to neutral while coasting to a stop. The car then won’t start for some time
Any update on this? I just bought a 964 3.3 Turbo project and although I don't know if I need one of these, I wouldn't mind having one for when I do.
Anyone? Bueller..,..
Hi Steve,
I hope all is well. any updates? |
Hi All,
Nothing definitive to report yet. Most of our time is being split between refinements for possible production and reverse engineering the ignition maps out of the 01 EZ69 and various Mercedes units. |
Thank you for the update
Thank you! We’re patiently waiting!
UPDATE,
As part of the EZL/EZ69 development, we have unfortunately discovered a little issue the Mercedes EZL as a cheap option. The fuel coding signal (mercedes) is on the same pin as the Porsche charge air temp sensor is on the 965. And the resistances are inverted between the Mercedes coding and the Porsche sensor! Therefore, as the intercooler heats up, ignition timing could advance by up to 6 degrees instead of retard by up to 2.8 degrees. Not good if you are wanting to protect the motor. The 538 and others are still likely a good candidates for a "Get me Home" emergency spare to keep in the toolkit, but really not a good choice for extended use. |
http://forums.pelicanparts.com/uploa...1755928164.jpg
Reverse engineering the maps is showing promise, but we have some variables in the bench test setup that we must eliminate. Digital replication of the input signals is fine for development but we can't be confident of any results unless the correct real world inputs and outputs are connected. Thus the above contraption is about to travel from it's home town to us here in Oz and be retrofitted to run a proper flywheel trigger setup and generate vacuum and boost pressure, while firing actual spark plugs etc. Essentially a desktop engine dyno. The 01 EZ69 we have here is not yet confirmed as functioning properly and there is a chance it is unhappy with the dummy ignition coil load we are using on the bench or it has a faulty temp sensor input, either way it is 7-10 degrees retarded from where it should be when above 2500 rpm. So, fingers crossed connecting a proper 965 ignition system might pull it out of safe mode and we can move forward. Chances of our module having a preloaded factory map -- maybe 50/50 at best Let the weird futility continue :D |
Is it correct to assume that the ez-69 either works or it doesn’t? There is no intermittent working vs not working?
Generally yes,
the primary failure is on the ignition coil output, which overloads and destroys itself. The Ignition transistor fails in two ways, it either goes open circuit, like a blown fuse, and simply stops the spark from working or it shorts out and then kills the rest of the EZ69 by letting 12 volts run around all over the boards inside. The 01 EZ69 I have here seems to have a different fault where the temperature sensor input has failed. So although it is still working, the timing has gone into an engine overheat temperature limp mode for safety. ( the 3K one on eBay a little while back) Intermittent faults are logically possible now that the units are 30+ years old, and I've run across some chatter that suggests it's happening. I also have a rare Mercedes 24valve one here that may fall in that category but we've not had a chance yet to look at it properly. |
Could take a while......... |
This is in contrast to EZ69 design which was domed to fail, especially in an engine compartment with temperatures exceeding 100C. Remember, the Mercedes Benz versions have a very low failure rate versus the Porsche EZ69 part! Those modules operate in a less severe environment. Where is your proof-of-concept development circuit board actually running a Porsche Turbo? Surely you have one, as a necessary step for any complex electronic circuity development, especially for a 965 ignition system. Post #54 describes a setup running on a test bench, but not actually running a 965 motor, or even driving an ignition coil - a critical development step. |
@mysocal911 I have a 965 running motor and would be ok trying the new units. And I’m in socal
| All times are GMT -8. The time now is 11:57 AM. |
