-   Porsche 996/997/991 Forum (http://forums.pelicanparts.com/porsche-996-997-991-forum/)
-   -   Unknown sensor (http://forums.pelicanparts.com/porsche-996-997-991-forum/1166734-unknown-sensor.html)
inaminit 09-07-2024 02:06 PM
Unknown sensor
This sensor or switch was dangling on its wire down on the passenger side of the engine on a 99 996. What is it and where does it go?http://forums.pelicanparts.com/uploa...1725743141.jpg
jchapura 09-08-2024 03:49 AM
It is probably number 4 temperature sensor in this picture. On my 2005 C2S, it controls the engine compartment fan.
http://forums.pelicanparts.com/uploa...1725792486.png
2mAn 09-17-2024 07:58 AM
Temp Sensor as mentioned above. If you've noticed your fan running overtime, its because this sensor is dangling out closer to exhaust heat.
Easy fix
FPB111 09-20-2024 12:46 PM
If the grommet is still in the manifold take it out and put it on the sensor before you try to push it through. If you leave it on the manifold you will push the grommet through and it will land on the dark side of the moon.
