Go Back   Pelican Parts Forums > Porsche Forums > Porsche 996/997/991 Forum
Jim (guest)
Guest
Posts: n/a
The passenger window on my 99 996 cab does not lower enough to clear the soft top weather striping. It does lower slightly when the door handle is pulled open. Other than that the window works fine. Do I need to replace the regulator? Make an adjustment? Thanks
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: 911 Window Regulator Replacement
Old 12-11-2011, 01:08 PM
Author of "101 Projects"
Wayne 962's Avatar
Yes, this is a very common problem with these. I struggled with the same issue on my car, trying to adjust it, etc. In the end, the regulator was just worn out / sloppy from years of use, and a new one fixed the problem. See this article here: http://www.pelicanparts.com/techarticles/Boxster_Tech/77-BODY-Window_Regulator/77-BODY-Window_Regulator.htm
- Wayne
MarKoBrow's Avatar
Originally Posted by Wayne at Pelican Parts View Post
Yes, this is a very common problem with these. I struggled with the same issue on my car, trying to adjust it, etc. In the end, the regulator was just worn out / sloppy from years of use, and a new one fixed the problem. See this article here: Pelican Technical Article: Boxster Window Regulator Replacement / Boxster Window Switch Replacement / Boxster Window Motor Replacement - 986 / 987
- Wayne
Hey Wayne, I have a 996 Cab that the window doesn't drop and or raise the 12mm on the passenger side as it does on the driver's side. Other than this condition the regulator works fine. Have you ever heard of a fix for that?
1997 911 Carrera Cabriolet
66 912, 67 912 Outlaw
65 Ac Cobra reproduction
2012 Audi A8L
1999 Ferrari 360 Modena
Old 12-25-2011, 07:07 AM
Hi, I have a strange variation on this problem. My passenger window sometimes wont go down, and sometimes it starts to go up and down, all the time!
Meaning it goes down 1/2", then up, then down, then up, you get the idea....
This happens when I close the door completely. It only stops either when I lift the door handle or when the door is open.
I just tried to leave it going up and down and thought it would stop eventually. After 15 minutes it was still doing the same thing.
Anyone who have an idea of what can be wrong?
Thanks,
Johan
-14 Cayenne S Diesel, DD
-92 964 C2 convertible, RS -92 look and feel😃
-73 T US MFI Targa, restored
-70 T Coupé Hot Rod, painted waiting for assembly
-72 T Coupé, US numbers matching under restoration
Old 01-07-2012, 07:48 AM
There is a a way to make the regulator adjustable. If you go to the 986 forum and search for permanent fix for window regulator you will fins it there. Also for the people whose window goes down when the handle is pulled but up when released you probably have a bad micro switch in the door latch mechanism. Unfortunately you can,t replace the switch and you must replace the whole mechanism which is a costly $200 part.
Old 01-14-2012, 09:28 AM
