Replacement engine number question
Hello - bought a 1999 C2 late last year- the seller gave me a copy of an invoice where Porsche replaced the engine in 2001 due to an internal coolant leak. The invoice shows the replacement engine number as M660166X16044. I thought that all these engine numbers started with M96. Thoughts? The car is stored right now, so I am unable to check the engine number for myself.
check this out, it will help you understand.
http://www.porscheclubgb.org/clientftp/Register/996/faq_engine_transmission_codes.pdf
Tony G 2000 Boxster S |
Thanks Tony- The only intrepretation that I can think of is that the M66 prefix is a typo-should be M96. The other numbers make sense after looking at your reference.
I agree. The engine stamping has to be M96 xxx etc.
Hell Belcho
These stampings are pretty damn hard to read. Im also thinking it was misread.
Saved by the buoyancy of citrus. |
