-   Porsche 996/997/991 Forum (http://forums.pelicanparts.com/porsche-996-997-991-forum/)
-   -   ODB code P0348 (http://forums.pelicanparts.com/porsche-996-997-991-forum/780417-odb-code-p0348.html)
Seeeu911 11-07-2013 03:57 PM
ODB code P0348
OBD code P0348 the info from my basic reader displays "camshaft position sensor A - Bank 2 Circuit high input"
Is a 2003 C4S 75k miles. I've a Durametric on order. Any thoughts ?
yelcab1 11-07-2013 08:35 PM
Codes starting with 0 are all generic codes required by law. This code says your cam position sensor impedance shows high values. It means your sensor is bad, or has a broken wire in the connector. The fix is to replace it. Clear the code, and drive.
Seeeu911 11-08-2013 05:44 AM
Good info, thanks !
JFP in PA 11-08-2013 05:57 AM
P0348 is telling you that the signal on sensor #2 is permanently high; most likely a failing cam position sensor. Fun to get at, but not a real problem to change out.
