2001 Boxster S Roller value
I have the opportunity to purchase a clean 2001 s roller. Engine state is bad/ unknown.
Is it worth 4k? Also what is a good source for a used engine? Thanks! |
Try the Boxster section of this forum
Try the Boxster section of this forum.
I'd try less...3k. Talk to Jake at Flatsix Innovations. He could rebuild that engine with all the upgrades and even increase engine size. You'll never worry about a used engine failing if you go that route and plan to keep the car.
Depends on condition and mileage of the rest of the car.
I would want to know the source of the engine failure -- that would help you know if your core is rebuildable or not. I would expect to pay $5-10K for your engine plus installation for a used engine. There are various sources of used engines with varying degrees of confidence associated with them. I have a 2.7 -- but not a 3.2 available. Mike
2015 Panamera Hybrid, 2008 Cayenne Twin Turbo 2001 996 GT2 1999 Spec Boxster, 1996 993 Cabriolet 1992 964 Cabirolet, 1975 911 RSR Replica Race Car |
