In your description of the coolant flush procedure for the 996 you say that the some of the spring clips should be replaced. Can you provide the part numbers for the various clips? thanks
__________________ This post was auto-generated based upon a question asked on our tech article page here: |
Here is what I found...
49mm clamp 999-512-348-02-OEM X 8 20mm clamp 999-512-554-00-OEM X 3 25mm and 28mm clamp 999-512-552-00 X 10 53mm clamp 999-512-669-09-OEM X 2 You should have everything you'll want to replace from that. This count may vary by year and model. - Casey |
