-   Porsche 996/997/991 Forum (http://forums.pelicanparts.com/porsche-996-997-991-forum/)
-   -   What is the recommended adhesive to use to re-glue emblem that is beginning to peel off? The tip of the C of the "Carrera" always becomes loose even shortly after a new replacement. (http://forums.pelicanparts.com/porsche-996-997-991-forum/865818-what-recommended-adhesive-use-re-glue-emblem-beginning-peel-off-tip-c-carrera-always-becomes-loose-even-shortly-after-new-replacement.html)
Ahimanic (guest) 05-18-2015 01:24 PM
This post was auto-generated based upon a question asked on our tech article page here:
Casey at Pelican Parts 05-18-2015 01:24 PM
I have never had success re-gluing those emblems. The glue is too hard to control after applied to the emblem and it usually becomes a mess of sticky fingerprints and is always obviously repaired. One thing I CAN tell you though is before you wash or dry the car placing masking tape over the Carrera emblem can prevent the emblem from being loosened by a rag or wash mitt. I have a detailer friend who NEVER wipes the emblem, only dries and cleans it using a blotting method. My final answer is to replace it and make sure that you carefully clean and dry around the emblem. Car washes are too harsh for the emblems.
- Casey
heligear 05-19-2015 03:02 PM
The original is held on with a double sided tape, you can get it at hardware stores, HD etc or possibly a body shop will let you have some, get the thinnest you can find.
FPB111 05-20-2015 04:50 PM
3M Super Strong Automotive Attachment Tape - 03609
Item #3M-03609
Regular Retail:$5.99, 4/$19.99
