LinkBack | Thread Tools | Rate Thread |
Guest
Posts: n/a
2003 996 C4S. Engine warning light comes on. Fault code reads that it is a knock sensor error. I replaced the sensor and cleared the code. After 50 miles or so I am getting the same fault and light. Any ideas what I should look for next. Otherwise car seems to run fine. Thanks
__________________ This post was auto-generated based upon a question asked on our tech article page here: |
Are you getting any irregular noises? Was the fault above or below limit? Open circuit or implausible?
- Casey |
