Go Back   Pelican Parts Forums > Porsche Forums > Porsche 996/997/991 Forum
mhariush's Avatar
OBD error codes, advice please
I got a check engine light yesterday on my 1999 C2 and as it turns out, my durametric (clone) cable just gives me a red light so I can't connect it. But I picked up a code reader from Harbor Freight today.
I get the following codes:
P0102
P0446
Any idea on where to start? Anyone experienced these? The car starts and runs like it always did
leave car or drive car while figuring this out?
Current: 87 944S Black/Black, 89 944 Turbo S ANDIAL White/Burgundy, 78 924 Black/Black, 17 Cayenne S, 03 Turbo X50 Aero
instagram @mhariush http://stores.ebay.com/Techniker-Parts/
Old 08-22-2014, 09:42 PM
JFP in PA's Avatar
Originally Posted by mhariush View Post
I got a check engine light yesterday and as it turns out, my durametric (clone) cable just gives me a red light so I can't connect it. But I picked up a code reader from Harbor Freight today.
P0102
P0446
First of all, when asking this type of question, always include the year and model of the car as it can make a difference in which is the correct answer.
Assuming it is a 1999 car:
P0102 - Mass airflow sensor below lower limit; likely faults: break in the wiring, short to ground.
P0446 - EVAP canister shut off valve below limit; likely faults: purge air line blocked, flow blockage in the EVAP canister
Accrochez-vous bien de vos rêves..........."
Old 08-23-2014, 07:30 AM
mhariush's Avatar
Hi, thanks. Yes, 1999 C2.
I see the codes, and I found what the OBD manual says about it. Is there any thing I should check before that? Is this commonly caused by something?
Someone also asked me if I had occasional trouble starting the car, and yes I do. If takes a few extra cranks to start it, I think. And a few times I tried starting it but it didn't, I had to wait a minute and try again.
Here's the OBD manual steps. Just start going through them then? I don't have the Special Tool, can I get around not using it?
P0102
P0446
Old 08-23-2014, 10:43 AM
JFP in PA's Avatar
You can get around using the "special tool", which is a Porsche specific pin out box, but it is going to be a lot more time consuming as you would need a digital multimeter and the car's wiring diagrams to test the circuits.
Old 08-23-2014, 12:46 PM
mhariush's Avatar
I cleaned the MAF. The air filter and inside of the air box was fairly "dirty" for a filter I replaced in July.
Cleared the codes. Let's see how that goes.
Live OBD data.
Old 08-24-2014, 02:27 PM
