Go Back   Pelican Parts Forums > Porsche Forums > Porsche Autocross and Track Racing
Help: Best Track Tires: Toyo RA1 or Yoko A032R
I'm looking to buy a set of tires for the track and have heard great things about both the Toyo RA1 and Yoko A032R. Or other suggestions.
We get a fiar amount of rain here, so something that is reasonable in the rain would be great.
Going on 7 & 8 x 16 wheels. Looking at 205/55 front and 245/45 rear.
What do you think is best?
Thanks,
Kevin
'88 911 Silver Coupe
www.CoachKevin.com
Old 07-05-2004, 09:55 PM
Administrator
Jack Olsen's Avatar
The Toyo is definitely a better track tire. Kumhos are better still, and Hoosiers are even better. Of course, lifespan goes down as you move up the pole.
Neither is great in the rain -- at least, not after they've been used very long on a track. That's what your street tires are for.
Old 07-05-2004, 11:13 PM
Kevin, Toyo's at full tread are the best in the rain. They are also pretty good shaved for a car up to 2700lbs. in the dry if laptimes are very important. If you are just starting to use R compound tires, I would go with the RA-1's, especially in your climate. I never had much luck with the Yoko's in the wet on my car('87 Carrera) but others have. Once the RA-1's wear down a bit you can use them as a dry tire and get another set for wet. I hope this helps.
Cheers, James
You will never know the feeling of a driver when winning a race. The helmet hides feelings that cannot be understood.
Ayrton Senna
1993 964 RS
Old 07-06-2004, 04:37 AM
Thanks James and Jack - that helps a lot.
Hey, is there a performance diffference between a 225/50 and 245/45 on the rears at the track? I think the 245 looks better, but want to know if it makes difference enough to justify buying wider Fuchs to mount the 245's on.
www.CoachKevin.com
Old 07-06-2004, 07:31 AM
Kevin, Assuming your car is stock(motor, suspension etc.) that tire is the way to go. I run 225 front and 255 rear but will be moving to 245 front 275 rear in the near future(I have headers and a chip plus a very aggressive suspension). A 245 in the back will be a good tire for you especially if you run alot in the wet or drive on the street. Plus they are cheaper!
Cheers, James
Ayrton Senna
1993 964 RS
Old 07-06-2004, 07:36 AM
Cheers, James
Thanks James, how the heck will you fit those tires on your car? Do you have falred fenders or something?
www.CoachKevin.com
Old 07-06-2004, 07:41 AM
No, Just some gentle persuasion. I run 31mm torsion bars in the rear too. I will probably put on Turbo flares this winter so I can run 315's in the back and 255's up front...
Ayrton Senna
1993 964 RS
Old 07-06-2004, 08:05 AM
