Rennch on YouTube
Hey. I'm looking to get a race wheel setup for my 72 911. I'd love to be able to afford some *****in Fikse setup, but that's not in the budget. My ideal is to get that 17X8.5, 17X10 setup, one way or another. Does anyone know if I can get steelies made in that size? Or another source for wheels that might get me in the ballpark? If I can't get there, 17 X 8's and 9's might be a good interim step...there were a set of CCW's on eBay that I bid on the other day, but didn't win. So...what's out there? Anything from another model year? Steelies? Old BBS?
Thanks for the input! mto
Michael O'Neal - 69 RSR Clone(ish) - The build: http://bit.ly/69porschersr 69 911S Blasphemy Build on YouTube Rennch Youtube Channel: http://rennch.com/Youtube Instagram: https://www.instagram.com/_rennch_/ |
"You go to the track with the Porsche you have, not the Porsche you wish you had." '03 E46 M3 '57 356A Various VWs |
Rennch on YouTube
I know! They are VERY tempting...but a bit out of budget.
You may want to try calling Diamond Racing Wheels.
Diamond Racing Wheels From a budget point of view, they are hard to beat. I'm in the same boat as you....budget! I have talked to several people who are running them and they have reported no problems. I need to buy another 2 sets of wheels for my track car, and these are by far the most economical. Best Regards, Bill P.
Bill Pickering 1974 914-6 2.7...aka...The Beast 1997 Boxster 2.5 track car...aka...Lucille |
Look at the "Avenger" series. They come in the 5x130mm lug spacing and take standard taper studs and lugs.
Bill P.
Rennch on YouTube
Bill...I wasn't under the impression that Diamond makes a 17...is that wrong?
In their road race series (Avenger), they make diameters up to 18" and in width's up to 14". Check them out.
The wheels I'm having built are 16x10's for my race car. The cost to me after haggling was $132.00 per wheel for two sets. One set would cost ~$145 each. Not bad..... Bill P.
Rennch on YouTube
I emailed them this morning. Will let the list know what's up...
Super Moderator
Souk has a line on some nice steel wheels, any offset.
Rennch on YouTube
Good to know...I'll drop him a line.
You will never know the feeling of a driver when winning a race. The helmet hides feelings that cannot be understood. Ayrton Senna 1993 964 RS |
Additionally, they are not hub-centric, they are lug-centric construction, so be prepared to find someone who can balance a lug-centric wheel in your area. They cannot be spin-balanced properly from the center pilot hole. They DO NOT come in "any offset and backspacing", as the dropwell section determines what can be built, and brake caliper clearance has to be caerefully measured before ordering. All that said, they are an outstanding value compared to any alloy wheel, unless you are trying to save every last ounce of unsprung weight. TT
Tom Tweed Early S Registry #257 R Gruppe #232 Rennlist Founding Member #990416-1164 Driving Porsches since 1964 Last edited by ttweed; 12-11-2004 at 07:50 AM.. |
Rennch on YouTube
Thanks Tom. What size did you get, and what did you put them on? Might you be able to provide me with the correct backspace and offset info? As far as balancing, it's for an autocross car, so it's not a huge issue like it would be if I were doing high speed stuff.
Thanks!
Hmmm, can I ask the threshold question, why?
I would think if you were AXing you'd want something that could spin up and down as fast as possible, with a small diameter, which coupled with some low profile meats could give you taller effective gearing.
'66 911 #304065 Irischgruen ‘96 993 Carrera 2 Polarsilber '81 R65 Ex-'71 911 PCA C-Stock Club Racer #806 (Sold 5/15/13) Ex-'88 Carrera (Sold 3/29/02) Ex-'91 Carrera 2 Cabriolet (Sold 8/20/04) Ex-'89 944 Turbo S (Sold 8/21/20) |
Rennch on YouTube
because I have a big motor in the car, and have the torque for it. I'm not going into this blind...people have come before me on this one.
Here's the current plan...16X8, 16X10 Diamond Racing Wheels. (So cheap!!!) 245/45-16 Fronts 275/45-16 Rears. What do y'all think? Can I cram them in there with the right amount of "influence?" (by a crowbar,maybe...)
I was hoping Souk would have this sorted out by now, as I exchanged email with him awhile back about these wheels, and I was hoping he would be the guinea pig. ![]() TT
Tom Tweed Early S Registry #257 R Gruppe #232 Rennlist Founding Member #990416-1164 Driving Porsches since 1964 |
Somewhere in the Midwest
Guys I had some conversations with Diamond Wheels a while back, but I have been swamped at work and at home. I'm hoping to visit with Diamond Wheels in the next month or two, but my earlier discussions with them was favorable.
I'll work on this..... Edit: I've got the '76 Bastard on the lift this week for some exhaust work amongst other things, so I'll take measurements. I have the front fenders off so it'll be easy to check inboard and caliper dimensions. I already know the outsides are as far out as I can get them with stock fenders (narrow) up front (7" fuchs with the lips rolled!). Last edited by MotoSook; 12-13-2004 at 07:36 AM.. |
Interesting clip I saw on the Speed channel last night. They took a car (Interga) that they are prepping for the track. They switched to larger rotors and from 16" to 18" wheels. They dynoed the car and came up with 8-10HP less.
Explaination: The engine now has a larger circumference to turn so their is more drivetrain loss. Moral of the story: Do go with larger wheels unless there is a good reason to (larger brakes). I'm actually downsizing from 17" to 15". My reasoning was the gear ratio on the 915s wear setup from the factory for 15". I get penelized for change OEM gear ratios.
Armando Diaz 85 911 Carrera - Track car 01 996 Carrera - For Sale http://forums.pelicanparts.com/showthread.php?s=&threadid=327823&highlight=996 87 944na - Old Daily Driver, now 944 CUP 03 Chevy Avalanche- Support Vehicle 70 Olds 442 W30 Conv- Gone but not forgotten http://www.diazracing.com adiaz@diazracing.com |
Rennch on YouTube
Armando,
Good points. Believe me...if I could get a 275/45-15 in a Hoosier AS04, I would be in heaven. Unfortunately for me, the wider tires don't come in smaller widths in "A" compound. Also...my car is actually geared a little *short* for my preference. It's a 72, so it has the 7:3:1 ring and pinion in the trans. It spools up really quickly, and I run out of gear pretty easily. So, I'm hoping to gain a bit of length in gearing, and a wider footprint out of the deal.
OK just thought I'd point that out. It was something new and never thought of before. Just sharing the wealth.
