How To Tell If Have LSD? For AX Classification (PCA GGR)
This is a dumb question, but how do I tell if my car (1989 Carrera) has a limited slip differential? I classed myself, ended up in AX13. Then as I was reviewing the results, I saw that I had denied having LSD, and that is a 30-point mod. I want to make sure I'm being accurate.
Also, where do I get the point deduction for the child seats? |
John,
Simply jack up the rear of the car (both rear tires off the ground) and spin either side's tire/wheel ... if the opposite side's tire/wheel moves in the SAME direction as the tire/wheel you are moving, then you have Limited Slip... If the other tire/wheel doesn't move at all, or moves in the opposite direction, then you don't. Hope this helps, |
When you talk to the houseplants, do they talk back? If so, you have LSD. If they're going door to door on bicycles, you have LDS.
:D
Look in your owners manual or open the trunk and look up at the under side of the hood. In both places should be about a 3x5 sticker with all the option codes for your car. 220 is limited slip.
Thom, speaking of LDS, if you're a fan of Trey Parker and Matt Stone, you gotta rent "Orgasmo". It's twisted and wrong, but in a good way. Funny as hell. |
Check your option tag as noted above, that's how I found out I had it. Sure wish I could actually make use of it though :)
I'm getting there.......slowly! -Chris |
No LSD, so I'm not a cheater.
limited slip
Just dump the clutch and hit the gas on a dirt road and take a look back behind you and tell me what you see.
How would a TB diff (Quaife) respond? |
Good question Colin,
I never tried spinning one on jacks... I would assume it would act the same as a LSD Cheers, |
| All times are GMT -8. The time now is 05:43 PM. |
