Go Back   Pelican Parts Forums > Porsche Forums > Porsche Autocross and Track Racing
jyl jyl is online now
jyl's Avatar
How To Tell If Have LSD? For AX Classification (PCA GGR)
This is a dumb question, but how do I tell if my car (1989 Carrera) has a limited slip differential? I classed myself, ended up in AX13. Then as I was reviewing the results, I saw that I had denied having LSD, and that is a 30-point mod. I want to make sure I'm being accurate.
Also, where do I get the point deduction for the child seats?
Old 03-16-2005, 09:37 PM
Chuck Miller's Avatar
John,
Simply jack up the rear of the car (both rear tires off the ground) and spin either side's tire/wheel ... if the opposite side's tire/wheel moves in the SAME direction as the tire/wheel you are moving, then you have Limited Slip... If the other tire/wheel doesn't move at all, or moves in the opposite direction, then you don't.
Hope this helps,
Chuck Miller
'73S cpe #1099 - Matched # 2.7/9.5 RS spec rebuild
'67 Malbiu 327 spt cpe - Matched # L-79 rebuild
Creative Advisor/ Message Board Moderator - Early 911-S Registry
R-Gruppe #88
Old 03-17-2005, 06:08 AM
When you talk to the houseplants, do they talk back? If so, you have LSD. If they're going door to door on bicycles, you have LDS.
Old 03-17-2005, 08:01 AM
PedalFaster's Avatar
Old 03-17-2005, 11:12 AM
speccar's Avatar
Look in your owners manual or open the trunk and look up at the under side of the hood. In both places should be about a 3x5 sticker with all the option codes for your car. 220 is limited slip.
email speccar@verizon.net
Thanks,
Mark
Old 03-17-2005, 05:57 PM
PRO Motorsports
Tyson Schmidt's Avatar
Thom, speaking of LDS, if you're a fan of Trey Parker and Matt Stone, you gotta rent "Orgasmo". It's twisted and wrong, but in a good way. Funny as hell.
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer)
'72 911T Targa MFI 2.4E spec(Formerly "Scruffy")
2004 GT3
Old 03-18-2005, 08:14 AM
Have you seen the South Park "All About Mormons" episode? PM me for the mpg link.
Old 03-18-2005, 11:25 AM
jyl's Avatar
The fern says I'm okay, he's okay. The cactus says "bite me".
Old 03-18-2005, 11:52 AM
And the ficus says "You wouldn't happen to have a tire patch kit and a pump, would you?"
Old 03-18-2005, 12:09 PM
Check your option tag as noted above, that's how I found out I had it. Sure wish I could actually make use of it though
I'm getting there.......slowly!
-Chris
1987 Guards Red Targa (sold)
2006 Toyota Tundra DC 4x4, the "man-e-van"
1998 CR500
Well on the fringe......
Old 03-18-2005, 04:57 PM
jyl's Avatar
No LSD, so I'm not a cheater.
Old 03-19-2005, 10:35 PM
Cool limited slip
Just dump the clutch and hit the gas on a dirt road and take a look back behind you and tell me what you see.
Old 03-20-2005, 04:13 AM
38D 38D is offline
38D's Avatar
How would a TB diff (Quaife) respond?
- Colin
GTC Motorsports, PCA Club Racing National Scrutineer
'92 Euro Cup #96ZNS498058 (PCA GTC1 #19)
Past '91 C2 Turbo (PCA D Class #38), '04 Cayenne S, '74 914-6 3.2 (236rwhp), '02 986S M030, '71 914-4 2.1, '76 914-4 2.0
Old 03-20-2005, 06:45 AM
Good question Colin,
I never tried spinning one on jacks...
I would assume it would act the same as a LSD
Cheers,
Chuck Miller
R-Gruppe #88
Old 03-20-2005, 07:36 AM
