How do I anchor my window net?
I need to finish installing my window net for Lucille. I have a spring loaded bar at the top to open, but I need to anchor the bottom of the net to the roll cage. I was told everything I need is at my local hardware store. Basically I was told to use metal cable.
How and where do I mount the bottom bar of the net? I need to meet SCCA regs.... Here's a pic. Thanks, Bill P.
Bill Pickering 1974 914-6 2.7...aka...The Beast 1997 Boxster 2.5 track car...aka...Lucille |
Driving member
Bill, if you have a GCR there is a good diagram of what you need.
Basically you need a support rod attached to the bottom of the net similar to the one you have on top. It needs to run horizontally far enough to reach the roll cage front and back. What I have seen most of the time is a loop welded at the aft end of the rod and hook type bracket on the forward end. To put the net in place you slip the aft end into the loop and pull down on the forward end to hook in place. The picture in the GCR shows this pretty well. If you don't have one I think you can go to the SCCA website and download it. Nice looking race car by the way. I have not seen a Boxster race car in person.
Jerry '86 coupe gone but not forgotten Unlike women, a race car is an inanimate object. Therefore it must, eventually, respond to reason. |
Driving member
Here is the website for the GCR.
http://www.scca.com/_FileLibrary/File/GCR2007.pdf It is a pdf. file site. as you should see. You need to go to page 87 and it has the info and diagram you need.
Thanks Jerry!
I was hoping I could use a cable tie solution for the netting but it appears it must be a rod. I was under the impression that you could somehow loop to the x bracing at the door entrance of the cage. I will need to schedule a visit to a shop as I do not have welding equipment. When the cage was built we have the spring loaded rod mounts welded to the top side, but the bottom side has a flat steel bar running through the loops. Bill P.
Driving member
You want to make sure that you install it so that in event of a crash it is easy to get out. The net should stretch just enough to hook and unhook in the front.
UFLYICU
Why not straps?
_______________________ Racer Rix Spec911 #5 prc-racing.com |
Straps or metal cabling is the way to go. That way when you release it it drops all the way down and out of the way so you can get out.
1985.5 944 GTS |
Rick,
Where did you get the straps and the lower bar and clamps? My cage guy set up the bottom piece I have for my net, but it is flat. Any suggestions on how to keep it from moving side to side? Thanks, Bill P.
UFLYICU
The Autopower net came with all the hardware from IOPort Racing supplies. The rods are round, and the stops are tightened with two setscrews.
UFLYICU
Here's some closeups:
Driving member
Are you guys running in SCCA with straps? The GCR clearly states
"Nets shall be attached to the roll cage: plastic buckles,cable ties, hose clamps and elastic cords shall not be permitted The diagram in the GCR is very clear on how they want it done. It may be that they will allow other setups but it does not mention it in the book and the cars I have seen are done like the diagram. Bill before you do it you may want to talk with someone in tech with the SCCA. You are apt to fail tech inspection if not.
Jerry '86 coupe gone but not forgotten Unlike women, a race car is an inanimate object. Therefore it must, eventually, respond to reason. Last edited by jester911; 07-23-2007 at 03:46 AM.. |
Wire rope (metal cable) with crimped ends is what I use for an SCCA legal mount. You can drill a hole in the lower metal (net) bar for the cable to go through, so you don't need anthing to "locate" the cable on that bar. Just loop the cable around the side door cage tubes and you're good to go! Looks like the front one would loop around the intersection of the X in the door, and the back one would just loop around the lower tube.
Jester - that diagram is a suggestion. It isn't the only acceptable method. Many cages do not have tubes that high in the door to allow the net to be mounted directly to a cage member. Cheers, Dean
'86 Carrera cab (euro) Spec Miata |
Hilbilly Deluxe
Here is mine:
![]() The rear of the bar goes into a tab welded on the cage, held in place with a cotter pin. A literal reading of the quoted rule from the GCR would make me think the net Zonas posted would be legal for SCCA, assuming the buckles on the straps are metal and not plastic. I race with NASA, and they require that "fasteners must be metal", so that one wouldn't fly. Tom |
UFLYICU
Rick,
I'm sure your installation would pass SCCA tech. But, I'm not a tech steward, so what do I know? ![]() See you at Thunderhill Aug 11/12? Cheers, Dean
One potentially easy answer for Bill is to contact Tony Coliccio at TC Design in Milpitas. He is familiar with all of the different rules and has probably built more cages in the past few years in the SF Bay Area than anyone else. I think he favors a cable approach, and even has special tools to terminate the cable.
Mike PCA Golden Gate Region Porsche Racing Club #4 BMWCCA NASA |
UFLYICU
![]() I agree with Mike about Tony Coliccio at TC Designs. He installed my net for me.
_______________________ Racer Rix Spec911 #5 prc-racing.com Last edited by ZOA NOM; 07-23-2007 at 07:08 PM.. |
I runn SCCA and I also have straps, have never had a problem. One thing I was told was to get rid of the alu lower bar. It flexes too much, use steel.
Armando Diaz 85 911 Carrera - Track car 01 996 Carrera - For Sale http://forums.pelicanparts.com/showthread.php?s=&threadid=327823&highlight=996 87 944na - Old Daily Driver, now 944 CUP 03 Chevy Avalanche- Support Vehicle 70 Olds 442 W30 Conv- Gone but not forgotten http://www.diazracing.com adiaz@diazracing.com |
