Go Back   Pelican Parts Forums > Porsche Forums > Porsche Autocross and Track Racing
(the shotguns)
berettafan's Avatar
19/26 T-bars in an early car...???
Anybody run 19/26 t-bars in an early car? Would like to hear how it handles (street, ax, etc).
Thanks,
Old 02-23-2009, 05:48 AM
I know this doesn't answer your specific question but I would consider 21/27. Great street/track compromise. I run this set-up on my SC and love it. This is combined with Bilstein sports on all four corners. I think Chuck from Elephant recommends a sport/HD combination with 21/27.
This set-up is a great compromise but as I progress on the track, I wish my set-up was a little stiffer.
2011 Cayman Speed Yellow
1988 924S (Sold) 2000 Boxster S (Sold)
2006 Cayman S (Sold) 1990 964 C2 (Sold)
1978 911 SC (Sold)
Old 02-23-2009, 06:50 AM
(the shotguns)
berettafan's Avatar
21/26 is what i am looking for but have located a set of 19/26's and am giving that some thought. i read somewhere here (i think) that some folks recommend against bumping the front bar size regardless of rears.
for ax i think 19/26 might be right decent but i'm afraid of ending up with a car that is on a knife edge in fast sweepers. i realize leaving an on ramp (er, i mean track) backwards at 100mph would make for a good story but i'm not really looking for material right now
Old 02-23-2009, 06:57 AM
DByers's Avatar
berettafan,
I run 19/26 on my 71 and it has been a great compromise. I also run an adjustable front sway bar up to 21mm and a fixed 19mm rear bar. Lowered to Euro specs. Optima battery in the smugglers box. 205/60/15 tires on 15X7's for the street on all 4 corners, track days see 205/50 RA'1s on all 4. Car with a 1/2 tank is 2150lbs. Some weight removal has been done. TRE did the CB and camber settings.
Car handles great for me. I can run Big Willow (long fast track) and feel very solid in turn 8 at 115-118mph or more. I can take the same set up to Streets (short lots of turns and technical track) and never experience any push. Car is very neutral. Car sees about 8-10 track DE's a year with about 8k in street miles.
Hope that helps. In car videos can be found on various posts by me in this section.
And 100mph + is not so bad going backwards in turn 9 at WSIR, just bring an extra pair of boxers!
Dan Byers
Old 02-24-2009, 07:16 AM
(the shotguns)
berettafan's Avatar
Dan thanks for that input. Sounds like you're maybe 300lbs lighter than me which is fairly significant. If anything i think this points towards looking at a stiffer setup for my car. Have located possible 21/27's and also possible 22/28's so we'll see what happens there.
Old 02-24-2009, 07:24 AM
Administrator
Jack Olsen's Avatar
I used to run 18.8/26 on my RS-style car. Relative to a track car, it's still a pretty soft setup (although the perception of these things are relative, I know).
I ended up switching to 21/30 before I, uh, drove that car into a concrete wall.
I went even stiffer (350/600# springs) with the next car.
Old 02-24-2009, 02:03 PM
26mm is about 35% stiffer than the stock 24.1mm's. This will make the rear rotate faster and the front bite better.
Might work on auto cross but I do not know if I would try it on a narrow body with same size tires ft & rr on the track but I would check with the experts.
Old 02-24-2009, 02:25 PM
