Go Back   Pelican Parts Forums > Porsche Forums > Porsche Autocross and Track Racing
2009 Cayman S Track Wheel/Tires
For DE's, I will be driving to/from event using "Extreme Performance Tires" track tires.
R/R stock wheel/tires with track wheels/tires at home prior to driving to event. Reverse when getting back home.
Same with brake pads. Street-->Track-->Street
18" wheels for street and track. Street set-up is stock 235/40 - F; 265/40 - R Using Hankook Ventus V12 evo tires
What size wheel/tires would you recommend for the track using "Extreme Performance Tires". i.e., Bridgestone R-11's; Hankook R-S3's or Michelin Pilot Super Sport's on 18" wheels? -->Width ? Offsets?
Track pads - Pagid Yellows
Thanks in advance
Old 08-01-2011, 01:57 PM
Bill Verburg's Avatar
Thanks in advance
for those tires 9.5" and 10.5" would be the ideal width for the wheels.
I've seen 11s on Caymans so fitting the 10.5 should be no big deal, not sure of the 9.5s though
8.5 ET55 and 10 ET42 are oem fitments and would work almost as well
Bill Verburg
Old 08-01-2011, 02:44 PM
Jeff Alton's Avatar
10.5 is no problem on the rear, aim for around a 38mm offset and it will clear even with aftermarket coilovers. For the front a 9.0 et51 or et44 is you change to upper camber plates or GT3 lower arms and get 2.2 or more degrees of negative camber.
You can also move to a 245/275 combo.
We have build many to those specs and ran the 9.0/10.5 combo on our own Cayman S.
Cheers
www.turn3autosport.com
Old 08-02-2011, 09:49 AM
gearhead
Just don't go too far outside of the stock parameters. The PSM&ABS don't like it. BGB fought with the ABS system for the better part of a season because of the tire size they were required to run in Grand Am.
1974 914 Bumble Bee
2009 Outback XT
2008 Cayman S shop test Mule
1996 WRX V-limited 450/1000
Old 08-02-2011, 01:02 PM
Jeff Alton's Avatar
The issue is with mismatching diameters not widths. Keeping the relative front to rear diameter ratio close to the way the car came keeps it all working properly. With the above mentioned sizes you have nothing to worry about.
Cheers
Old 08-02-2011, 08:06 PM
gearhead
Yes, it's a diameter issue.
1974 914 Bumble Bee
2009 Outback XT
Old 08-03-2011, 03:53 PM
Large Registered Member
PatrickB's Avatar
If you run the 245/275 combo, there is no better off the rack street legal tire than the
Nitto NT01. UTQ of 100, and I guarantee you will get twice the track days AND GRIP on them then any of the above listed tires. If you get some negative camber in that car, you might see 8+ track days on a tire you can drive back and forth to the track. Run them till you see cord! Kuhmo V710 and Hoosier R6 offer better grip, but you might only see 4 track days out of the 710, and maybe 3 out of the R6 with both not being street legal.
'85 Carrera Coupe, Marble Grey #118 JP/R6
'93 Lexus SC400, '00 Ford F-150
'70 911T- 2.7 (SOLD)
Old 08-03-2011, 10:04 PM
Jeff Alton's Avatar
What Patrick said...
Old 08-03-2011, 11:21 PM
