Go Back   Pelican Parts Forums > Porsche Forums > Porsche Autocross and Track Racing
crikett's Avatar
Hoosier A6 Question
I'm considering mounting up some A6s on 15" wheels, which would mean 225/45/15s all the way around. Looking at the specs, namely the load ratings... wondering how this will work (but also thinking that the load ratings could be way off due to the way tests are done and not really suited to compeition tires).
So, anyone out there running this setup (car is slightly lightened 3.2L Carrera... probably around 2650# or so)?
Old 09-29-2011, 01:27 PM
I've had great results with this setup, but my car weighs 2k. Why not run the 275's on the back of your heavier car - are you lacking the 9's to mount them?
David G PCA
'72 S/T
'74 Euro Carrera
'95 RS --SOLD
'77 930 Steel Slantnose "Wedgie"
'57 Speedster planter
Breeding family of Volvo/ BMW Wife + kid mobiles
'Rib-Breaker' '01 CRG 125 shifter kart
Aprilia RS50-weedeater with fairing
Old 09-29-2011, 05:32 PM
racer's Avatar
225/45 work fine all around (certainly in AX, likely too for track). Seems the current "hot" set up is a 275/35-15 as mentioned, but you would likely need a 9" or 9-10" wide wheel.
hopefully you have some supension adjustment (ie, sways) to fine tune and under/oversteer concerns due to the square footprint.
Past:
2000 Boxster 2.7, 1987 944, 1987 924S
1978 911SC, 1976 914 2.0, 1970 914 w/2056
Old 09-29-2011, 05:41 PM
crikett's Avatar
Thanks for the feedback... indeed, running 7s and 8s here. Will give them a go and see how it works.
Old 09-29-2011, 06:44 PM
Super Moderator
cstreit's Avatar
Why not 245 rear? I dont think load rating is an issue either way...
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 09-29-2011, 07:03 PM
crikett's Avatar
I'd love to go 245s. Hoosier offers quite a few different sizes in the R6, but with the A6 it's just the 225/45 or 275/35. After this set I should be moving over to some 16s, and will be doing the 245s in back then.
Old 09-29-2011, 07:06 PM
Evan Fullerton's Avatar
I have run 225/45/15 A6s square on 15X7" for a while and it is fun but not ideal, some day I will buy some 15X9" wheels and switch to the 275 rear. Since you have the space (I don't...yet) I would put as much spacer on the back as you can. The gain in rear track width should compensate for the lack of stagger some what.
Old 09-29-2011, 08:03 PM
The 245/45 16's don't gain you much over the 225/45 15's - 9.2 vs 9.0 tread width. The real deal is the 275/35 15's - 10. 1 tread, and only 23" tall, to match the 225/45 15's. A whole inch lower + shorter gears = more fun.
David G PCA
'72 S/T
'74 Euro Carrera
'95 RS --SOLD
Old 09-29-2011, 08:20 PM
